02-16-2005, 01:11 AM
#12
Mo' valves, mo' boost
My Ride: Daytona ES
Engine: 2.4L DOHC
Does the clutch pedal feel about as firm as it did before? Or does it take more/less pressure to push it down? Also, with the hood open and the car idling in neutral, push the clutch pedal down then let it up a few times. If the clutch is indeed grabbing, you'll be able to hear a faint "whirring" sound when the clutch pedal is up.
As far as the throwout bearing being installed incorrectly, I would think that it would make some AWFUL sound if the fingers on the pressure plate were up against anything other than the bearing, but I could be wrong. And just like the other guys said, just double-check for the stupid stuff. It happens. Hell, about a month ago, I was changing the oil on my brothers new Hemi Ram, ran in the house for a phonecall halfway through it, came back out and put 7 fresh quarts of oil on my damn garage floor!
