02-13-2005, 12:07 PM
My Ride: 91 Spirit R/T
Engine: TIII
Pop the cables off the trans and try to get it into gear by moving the selector with your hand. Without the mechanical advantage from the shifter you may be able to feel a problem.
02-13-2005, 02:00 PM
Engine: TIII
The shaft should move in and out relatively easy. There will be some spring pressure both ways; this is the pressure that puts your shifter back to the nuetral position between 1st and 2nd. It should not bind or catch on anything. You may notice that there could be some extra pressure when you pull it out all the way; that is where reverse is.
It should also rotate side to side and engage the gears. The pattern is going to be identicle to your shifter pattern.
front of car<--5..3..1..R
.......................4...2
I can't remember which way it will rotate to engage the gears, though you should be able to find them all. reverse is all the way out though.
There should be no grinding since you should be doing this with the engine off. You may need someone to press on the clutch pedal to ease going into gear. It should feel just like it does inside the car but more precise. The shifter cables give a bit of a rubbery or vauge feel, this is closer to a nice RWD shifter or a bolt action rifle.
02-14-2005, 01:20 AM
Engine: TIII
Nice tranny mount, is that custom?
Look at the bright side; any shifter housing from the same year 555/520 will work for you. If you can't find one locally I have one in my garage I don't have a use for since the rest of the case is cracked up.
02-14-2005, 12:04 PM
Mo' valves, mo' boost
My Ride: Daytona ES
Engine: 2.4L DOHC
WOW, and that's the mount that hardly ever breaks.
