02-13-2005, 06:52 PM
The upper or lower one? I'm pretty sure you can get the bottom one out quite easily... take off 2 bellhousing bolts, and the small 10mm bolt, then wiggle it out. The top one might be a different story, I can't really recall because I don't think I have ever put one back on... haha. (Just remembered...) I think the top one has a 10mm bolt inside the bellhousing, if you put it back on properly you probably couldn't get it out without getting real fancy.
The last time I put the engine back my 87 I put the shield back on (just the bottom one, I think) it was banging real loud, real annoying... we just got a prybar/screwdriver in there somehow and bent it back... I can't totally recall. I doubt I'll ever use one of those shields again
I'm sure it just stops rocks/dust/debris from getting into the bellhousing area... as long as you don't do excessive gravel/offroad driving I'd think you'll be ok, unless someone else has a horror story they'd like to share.
