Old 02-15-2005, 08:59 PM   #1
Exclamation synchro ring in A525
My Ride: '84 GLH, '04 R/T
Engine: 2.2 HO, 2.0 Magnum
my GLH HO has a slight grind going into 5th, im pretty sure its the synchronizer ring. who hard is that to replace?
vntned is offline
Old 02-15-2005, 11:17 PM   #2
My Ride: 91 Spirit R/T
Engine: TIII
That is not very difficult at all to replace. Take the side cover off and then youcan get to the 5th gear asembly. you should just have to remove a snap ring and either a roll pin or hex lock screw to get the syncro assembly off. Try to get a page or two photo copied from your local dealer FSM so you know the exact procedure.
86Shelby is offline
Old 02-16-2005, 06:34 AM   #3
My Ride: 1991 Daytona Shelby
Engine: 2.5L
You sure its not your cables? 5th gear is at the end of the travel for both cables. I would check your bushings... same problem happened to me.
AHHHH CRAP!!! 525. Oh well.
Frank
Frank is offline
Mortgages | MPAA | Advertising | Mobile Phones | Credit Card Debt Consolidation
Page generated in 0.29339 seconds with 13 queries
