Old 04-07-2005, 09:46 PM   #1
what Tranny comes with a 2.2 dodge shadow?
My Ride: Dodge shadow
Hiya,
I was wondering what tranny will go with the 2.2 dodge shadow engine?? I checked the bottom of mine, and it has the following 424-11-A is this the model???
Will this tramission do with a 2.5 turbo that is if Iam able to do the swap from the 2.2 to the 2.5.
thank you
Koqui is offline
Old 04-07-2005, 09:50 PM   #2
Is this a turbo or n/a, auto or standard?
Old 04-08-2005, 02:11 PM   #3
its an automatic N/A trasmission. would I have to replace it if I get the 2.5 engine?
Koqui is offline
Old 04-09-2005, 07:41 PM   #4
My Ride: 1995 Intrepid
Engine: 3.3 v6
It would be an A-413 Tranny
One_Fast_Omni is offline
Old 04-11-2005, 12:17 AM   #5
Don't use that trans in a 2.5L turbo application. The turbocharged application A-413's have an additional clutch or 2 in the drums and different governor weights to handle the additional torque output. There could also be differences in the planetary gears as well.
Jckrieger is offline
Old 04-14-2005, 09:38 PM   #6
A friend of mine gave me a dodge tranny with the numbers 424-6-b, He didn't know what model of car it was, Would anyone tell me what these number stand for, like the 424-11-a stands for a-413. Would it work with a 2.2 89'shadow?
thax
Koqui is offline
Old 04-14-2005, 10:55 PM   #7
If your axles fit in the differential and if the torque converter fits the front pump, it should work fine. I'm not sure if it'd matter if it's lockup or non-lockup.
Old 04-15-2005, 11:10 AM   #8
He also handed me out the converter if im not mistaken, its a big rounded dome looking thing?
Koqui is offline
Old 04-15-2005, 01:13 PM   #9
Then you should be fine
Old 08-09-2006, 10:01 PM   #10
Well back to this, I finally got a 2.5 engine by mistake, but to my luck the 89 model need a computer, I took it back to the shop and I hoping in getting the 2.2 89 engine. now the thing is that i rebuilt the 2.5 tranny, and Im wanting to know if it would fit on the 2.2 89 engine that I will be getting... This is what I have right now
89 dodge shadow
with a 2.5 93' engine and Tranny, which I need to return since I dont find the Computer on any junk yard. Since it would be an engine swap only will the 2.5 Tranny Break the 2.2 or Viseversa?
Thank you
Koqui is offline
Old 08-09-2006, 10:46 PM   #11
it all works together and doesn't matter one bit. 2.5/2.2 transmission, engine computer, just slap that puppy together and go. no need to worry about a darn thing. the 2.2 trans and 2.5 trans are exactly the same!!!, the 2.2 computer will work just fine with the 2.5 engine. you won't notice any issues what so ever.
22dodge is offline
Old 08-09-2006, 11:23 PM   #12
speedyshelby16's Avatar
My Ride: Shelby Charger
Engine: 2.2 turbo II
Images: 8
Just let you everything will swap like said above but it has to be turbo parts no mixing of N/a parts.
Also a 90 and up computer won't work in a 89 and down. Your computer years are 88-89.
Check them out.
speedyshelby16 is offline
Old 08-30-2006, 11:13 PM   #13
The reason why im Changing my engine back to the 2.2 89 is because my engine surges. when hot, I have changed everything on that car, and I still get the same results. to mention I have the 2.2 coil running on the 2.5 which someone mention it was ok, just a bit hotter. I have my dodge sitting in the garage, and I dont know where to turn to. I figure If i was to take it to a mechanic he might just flip and order pieces I wont need.
Again its a dodge shadow 89 2.2 engine with a Swap 2.5 93' engine.
Please Help
Koqui is offline
Old 08-31-2006, 01:30 AM   #14
Ok, if I wasn't confused, I am now.
What engine did your car originally come with?
Does it have a turbo on it-from the factory?
What have you done to it at this point and does it have the factory computer in it?
Old 08-31-2006, 03:32 PM   #15
I'm going to guess you shadow isn't a turbo. If that IS the case, the engine and any trans you want to swap will be fine. You should have a distributor on both engines not coil packs like on newer cars (or Turbo III cars, which yours isn't I'm guessing). I'd probably just try to swap short blocks, and transmissions, leave the electronics alone.
b82colwell is offline
Loans | Electricity Suppliers | Credit Card | Myspace Layouts | Informatica Descargas
Page generated in 0.53247 seconds with 13 queries
