06-21-2005, 05:30 PM
syncro/stop ring noise troubleshooting
My Ride: shelby lancer 2.5hyb
I have had noise in my 568 since rebiulding it a year ago. I havent driven it much due to this. The noise in in neutral with the clutch ingaged , sounding like a bad bearing on the input shaft. There is more brass particles in the oil than normal.
So I decided to go back in a figure it out. The brass makes you think syncro.
But first, after removing the input and interm. shaft. I put the input shaft back in and started the engine. This is with the bearing support plate on but not the gear selactor cover or end cover. It purred, with no noise at all. Some might think this will hurt the bearings since there was no oil in the trans. But a taperred roller bearing can be lubricated with the oil you could place on the head of a needle. Anyway, then I placed the intermediate shaft in the trans with out 1-4th gears on it, but put 5th gear on the outside of the bearing support plate. Started the engine and again NO noise. SO then I placed 1-4 th grears on the interm shaft and left 5th gear off. Started the engine for about 20 seconds and sure enought the noise is there. So then I reached in the top cover and moved the 1-2 syncro a little. No change in the noise at all. But when I moved the 3-4 syncro the noise changed a lot.
So the problem is in the 3-4 syncronizer. I carefully disassembled the syncro and could see a lot of brass particles on the tappered cone of the 4th speed gear. I have never had a stop ring go bad like this.
Can anyone assure me that this stop ring is going bad and just needs to be replaced. I cannot see anything else damaged in the 3-4 syncro.
Have two stop rings on order and should have the car ready for SDAC.
Could the cable be out of adjustment?
Thanks
Andy
Cincinnati
