Old 01-08-2006, 11:02 PM   #16
speedyshelby16's Avatar
My Ride: Shelby Charger
Engine: 2.2 turbo II
Images: 8
note I got the cheap ones. The rears feel alittle soft compair to how stiff the front is. There not a direct swap for the rear you will need to make some to get them to work.
Check them out.
speedyshelby16 is offline
Old 01-08-2006, 11:29 PM   #17
My Ride: 2 omni's
what did you have to do to the rear?
LOCOBLAZER is offline
Old 01-09-2006, 12:08 PM   #18
Images: 8
The rear strut I had where smaller then THe adjuster sleve. So I took the factory washer on the spring mount add about a 1 3/4" of pipe that was a 1/4" pipe with a two inch inside to it go new washer from the store and and bored a hole about the same size the shock body. Then took a 2 inch out side dia pipe and center it on the top washer so the adjuster sleve had some thing to mount to and not slide around.
Check them out.
Old 01-09-2006, 02:39 PM   #19
My Ride: 86' GLH Omni
Engine: 2.5 Turbo
Is there any chance you have pictures of the rear struts???
me_2_3_5 is offline
Old 01-09-2006, 09:29 PM   #20
My Ride: 2 omni's
yes pics would definetly help. i just got confused. (haha damn visual learner
Old 01-09-2006, 10:46 PM   #21
Images: 8
If this don't work I guess I will have to take a wheel off my car to show you guys.
Check them out.
Old 01-09-2006, 11:13 PM   #22
Engine: 2.5 Turbo
Is the rear suspension really stiff?? i am up against a really soft rear end so its slowing me down ALOT....
me_2_3_5 is offline
Loans | Gas Suppliers | Dominios | Credit Cards | The eBay Song
Page generated in 0.37019 seconds with 13 queries
