01-09-2006, 02:39 PM
#19
My Ride: 86' GLH Omni
Engine: 2.5 Turbo
Originally Posted by speedyshelby16
The rear strut I had where smaller then THe adjuster sleve. So I took the factory washer on the spring mount add about a 1 3/4" of pipe that was a 1/4" pipe with a two inch inside to it go new washer from the store and and bored a hole about the same size the shock body. Then took a 2 inch out side dia pipe and center it on the top washer so the adjuster sleve had some thing to mount to and not slide around.
Is there any chance you have pictures of the rear struts???
