Old 01-08-2006, 10:58 PM   #1
Any one run 225/50/15's on an omni?
My Ride: 86 GLHS #238
So, has any one run 225/50/15's on an omni GLH or GLHS? Any pros or cons? Pics???
GLHS#238 is offline
Old 01-09-2006, 01:30 AM   #2
I dont think they would even come colse to fitting unless you have a set or rally springs, even then they would probably rub.
Travis_k is offline
Old 01-09-2006, 11:32 AM   #3
My Ride: 1986 Dodge Omni GLH-
yeah, my 205-50-15 rub ever so slightly on the insides. not enough to wear through, but enough to see marks. don't think the 225 would come close to fitting unless there was some spacers and taller springs.
devlish is offline
Old 01-11-2006, 11:06 PM   #4
speedyshelby16's Avatar
My Ride: Shelby Charger
Engine: 2.2 turbo II
Images: 8
I got 225 50 15 on my SC with no rubbing but I do have after market rims on it.
Check them out.
speedyshelby16 is offline
Old 01-12-2006, 12:09 AM   #5
The Pope's Avatar
Mopar sold a rear swing arm that had a built in 1" sway bar and was 1/4" wider on each end and the 225s fit. Also you can trim the inside of the GLH air dam so it doesn't rub. The rear is a 1/4" thick piece of plate steel with the holes drilled in it for under the spindle, thats easy too. They barely rub the rear springs. The Omni from hell that ran the one lap ran the whole event with 225s.
The Pope is offline
Old 01-12-2006, 05:34 PM   #6
I have 215/50's on my Omni. It's a stock car, with 6.5" crabs on it. No rubbing at all. I am pretty sure I could fit a 225/50 on there as well.
1985ShlbyChrger is offline
Old 01-12-2006, 05:37 PM   #7
I had the 6.5" pizza wheels on my GLH with the 225/50/15's and there was a slight rubbing but nothing too bad. It looked alot tougher too.
moparmaster is offline
Myspace Proxy Directory | Mortgage Calculator | Bad Credit Loan | Free Advertising | Xecuter 3 Mod Chip
Page generated in 0.37363 seconds with 13 queries
