04-18-2006, 03:20 PM
here's what I did: I have crab rims on my 88 shelbyZ that were stock and getting to be pretty ratty, especially the clear coat. I bought some spray can ("tal-strip" i think it was) paint remover and sprayed some in the plastic cap that came off the can or any suitable container. I took the wheel off and set it horizontal and used one of those small epoxy brushes to brush on the paint stripper just on the polished part of the rim. The clear came off fast and you can wipe it off with a rag fairly quicky (use gloves too). The reason for using the spray-on stripper is that it works and dries much faster than the regular brush-on type. My polished lip looked like NEW then, I will not be putting any more clear on, just regular polishing. Since that turned out so well, I thought..hmmm..and bought some medium gunmetal gray metallic wheel paint, and after masking off the polished lip, sprayed that on in a couple good coats after sanding the center a bit. WOW, looks way way better, the darker color sets off the polished outer rim perfectly, and get this: only took me one hour to do all this. Very, very easy. Doing it this way leaves the metal in perfect condition, and doesnt require re-polishing. This would be a perfect way to go for those that just need to get rid of that peeling and yellowing clearcoat. I'll try to get a pic posted soon. You could do this with just about any color, gold, black, gunmetal, bronze, or even painted same color as the car, would all look awesome, probably much better than the plain factory silver. Bonus: now your rims look like most factory Shelby-supplied rims with gray or gold centers.  Let me know how it works for ya..
