Old 04-11-2006, 12:51 AM   #16
Hybrid Booster
My Ride: '87 Shelby Z
Engine: '87 2.2L T-2
Images: 3
Originally Posted by Una
You can't pull the hub off, it's pressed in. It's essentially part of the knuckle..
So, I unbolt the entire suspension from the knuckle and hub assy, then I can replace the bearing? What a pain in the ass, all this just so I can pass tech inpection...f-en old ass car.....
Sonic1979 is offline
Old 04-11-2006, 01:17 AM   #17
If you really want to you can upgrade to the newer knuckles with bolt in bearings... and ps most new cars are the same way.
Daniel Merrill
89acclaim is offline
Old 04-11-2006, 09:28 AM   #18
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
tech inspection? What state are you trying to register the car in? There is no tech inspection in this state.
Una is offline
Old 04-11-2006, 10:03 AM   #19
Hybrid Booster
Images: 3
Not register, pass tech at the track, they told me that I couldn't auto-cross because my bearings are too worn out, so out with the old and in with the new
How hard is it to upgrade to the newer knuckles?
Old 04-11-2006, 02:10 PM   #20
Una
Engine: 2.5L Turbo
Ooooh.. heh, dur.. That makes sense..
Upgrade to newer knuckles.. You just have to find a set. I have a set, but I'm not sure I want to give them up.. They have brand new premium pads, new 11.25" rotors, and good bearings.. They stop hella well. They're still on my Daytona that I'm parting out.. I'd let them go for $150, even toss in the 24mm master cylinder if you need it..
Una is offline
Old 04-12-2006, 10:15 AM   #21
Hybrid Booster
Images: 3
What car(s)/year(s) are these originally offered on? Can they be found in a boneyard? How much would they charge me if I went and pulled them myself?
Old 04-12-2006, 03:36 PM   #22
Una
Engine: 2.5L Turbo
'89+ fancy models.. heh.. I found mine on an '89 Daytona ES originally.. The nice Lebaron's got them, really nice Spirit's..
If you could find them, I think I spent $75 on them.. Not counting the rotors and pads I put on later. And that was at the dirt cheap junkyard in Lynnwood.
Oooh.. And keep in mind, swapping upgraded brakes onto your car will bump you out of the stock class in autocross. If that's something that's important to you..
Una is offline
Old 04-12-2006, 05:09 PM   #23
Hybrid Booster
Images: 3
Check out my Cardomain site http://www.cardomain.com/ride/2134729 and then tell me if the brakes will really affect my class placement....
Old 04-12-2006, 08:13 PM   #24
Una
Engine: 2.5L Turbo
I'm not totally sure about the class thing. You might send a PM to Sherri007 on here, she's pretty familiar with autocross rules. I've never tried autocrossing, I prefer drag racing..
Una is offline
Old 04-13-2006, 03:20 PM   #25
Hybrid Booster
Images: 3
Are you coming out to the Brem Racestrip this weekend?
Old 04-13-2006, 07:24 PM   #26
Una
Engine: 2.5L Turbo
I think it's going to get rained out again.. OTherwise, I'm just flat broke anyways.. Just spent $200 upgrading the exhaust on the Omni.. That sucked.
Una is offline
Old 04-13-2006, 09:58 PM   #27
My Ride: 85 GLHT, 87 ShelbyZ
they're stock, just stock 89 brakes Minivans for the fronts, just gotta swap to the smaller bolt pattern hub. and Daytona shelbys. Lebaron GTC's, some Daytona ES models and R/T's etc is where you find the rears. Just look for vented rear rotors. That's the ones. You'll want the PP valve and the MC as well unless you use a dodge D150 truck MC.
GLHNSLHT2 is offline
MPAA | Mortgages | Forex | Best Credit Cards | Loan
Page generated in 2.47766 seconds with 13 queries
