Old 04-06-2006, 10:33 PM   #1
Is it feasable
Hybrid Booster
My Ride: '87 Shelby Z
Engine: '87 2.2L T-2
Images: 3
Is it at all a possibility to be able to remove and replace the front and rear wheel bearings with out removing the steering knuckles etc etc just the bearnings, not the whole hub, just the bearings
Sonic1979 is offline
Old 04-06-2006, 10:52 PM   #2
My Ride: 1990 Daytona ES
Engine: 3.0L V6
what year and model are we talking about?
roguetrip is offline
Old 04-06-2006, 11:05 PM   #3
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
It's a 15 minute job to pull the front steering knuckles. The bearings are pressed in, you can't just remove them. Need some front knuckles with good bearings? I have several in my shed.. I'll even help ya install them if you'd like.
Una is offline
Old 04-06-2006, 11:59 PM   #4
My Ride: Shelby Daytona
They make a tool set called the Hub Shark. I think thats the tool youre looking for. It'd be cheaper to just take off the knuckles, have a shop press in new ones and have an alignment done. Like prob $300 cheaper.
afsautoworx is offline
Old 04-07-2006, 12:29 AM   #5
Hybrid Booster
Images: 3
'87 Shelby Z, would going to the boneyard and pulling off a few hubs be easier than trying to do what I am doing?
With the hub removed, can I just pound put the bearing(s) and use a vice or something to get it all back together. I bough just the bearings from schucks...
Old 04-07-2006, 09:41 AM   #6
Una
Engine: 2.5L Turbo
No, you cannot just pound them out. Yes, if you want to keep the car on the road, you should either go to a junkyard and get some used knuckles, or contact me, and I'll give you a pair of them. Then you can install the bearings into the new knuckles. If you do go to a junkyard to get knuckles, don't go to any in Kitsap County, they'll rip you off. Probably $45 or more each.. Go to Pull-A-Part in Lakewood.. Bit more of a drive, but you'll get them for $17 each instead.. And you can get them off most any turbo Dodge from '86 to '89.. Lebaron, Shadow/Sundance, Lancer.. Anything except Charger/Omni..
You will need an alignment when you're done. ($45 at Les Schwab)
Una is offline
Old 04-07-2006, 11:25 AM   #7
Hybrid Booster
Images: 3
Where are you located? Can we meet up somewhere for the hubs? How much do you want for them?
Old 04-07-2006, 03:59 PM   #8
the press-in bearing delima is just one situation i did away with by converting my 89 spirit es to 91+ knuckles and brakes (dynasty donor)
capev86 is offline
Old 04-07-2006, 04:22 PM   #9
Hybrid Booster
Images: 3
What about the rear bearings? Are they too, just as much of a pain in the arse?
Old 04-07-2006, 04:45 PM   #10
Una
Engine: 2.5L Turbo
Rear bearings are a breeze, simple to do at home.
And I'm in the autocenter in Bremerton.. I work there, and I live a couple blocks away from it. Yeah, no problem meeting up sometime. email me, unaclocker@gmail.com
Una is offline
Old 04-08-2006, 12:52 PM   #11
My Ride: '86 Lebaron 'vert
Engine: 2.2 T1
check with your auto parts store, they may rent you a hub shark tool.
otherwise, it's best to pull them. just make sure you scribe a mark on the cam bolt and strut body so you can set the camber close to where it was
stinger is offline
Old 04-08-2006, 02:08 PM   #12
My Ride: 85 GLHT, 87 ShelbyZ
upgrade to 89 big brakes, then the bearings bolt in and out. Don't even have to remove the CV axle.
GLHNSLHT2 is online now
Old 04-10-2006, 11:15 AM   #13
I went through that the other day. I bought the hub kit, swung out the knuckle to save the alignment, air chiseled out the old berring ( carefuly not to gouge anything ), got a thick piece of threaded rod with a nut and plate at either end to suck the hub in and walla. (easier with two people and a hella big bar to swing the arm down from the knucle)
Mini-man is offline
Old 04-10-2006, 09:20 PM   #14
Hybrid Booster
Images: 3
Now Im having issues pulling the hub off, the chiltons shows 4 bolts to unbolt the hub from the knuckle, I have removed everything and there are not any bolts holding the hub to the knuckle, do I have something weird? Did the Shelby Zs recieve a weird brake/hub area assy?
Old 04-11-2006, 12:01 AM   #15
Una
Engine: 2.5L Turbo
You can't pull the hub off, it's pressed in. It's essentially part of the knuckle..
Una is offline
Mortgages | News | Mobile Phones | Personal Loan | Cheap Car Insurance
Search Engine Optimization by
