Old 04-10-2006, 10:05 PM   #1
raise my rear ??? turbo mini
i installed a hitch on my mini and it seams pretty low to the ground so i was wondering how i can raise the rear end so that the hitch doesnt drag on the ground when i hook my trailer and race car on the back. lmk
2fst4u is offline
Old 04-10-2006, 10:19 PM   #2
What kind of hitch did you put on? Mines lowered 2 1/2 inches and the hitch has never hit the ground, even towing my 2000lb 12x7 enclosed trailer. You might have to buy a raised hitch bar to even out the load, mines 5 inchs high if i remember correctly.
Old 04-11-2006, 11:51 AM   #3
even the lowest uhaul or reese hitch has never been an issue in the 100+ caravan's I've owned. are you sure YOU installed it correctly?
allmotor is offline
Old 04-11-2006, 04:27 PM   #4
maybe he's talking about rear end sag w/ the load on. annoys me w/ all my cars and trailer towing. mopar stopped making their G body rally springs that raise the car 1" and give a firm ride. i wanted a pair for the back of my k wagon....arghh. on a c'van its an easy job to just use a pair of add a leafs from jcwhitney or whatever. that's how i'd do it.
capev86 is offline
Old 04-11-2006, 04:41 PM   #5
i put a reese hitch on and it seams pretty low to me but then again i might just be paronoid. the hitch does however bottom out on parking curbs if that helps. how much room should be between the bottom of the hitch and the ground ??
2fst4u is offline
Old 04-11-2006, 04:57 PM   #6
Have you tried different shocks, i am using the Rancho 9spd shocks, but only on setting 3 for daily use and setting 5 for towing. My hitch is aprox 4-5 inchs from the ground, and remember, mines lowered.
Old 04-11-2006, 05:07 PM   #7
i am going to be buying some new shocks this weekend cause i think that will help my problem
2fst4u is offline
Old 04-11-2006, 07:52 PM   #8
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
i just took my hitch off. i never use it.
turbo minivan is offline
Old 04-11-2006, 09:20 PM   #9
shocks don't affect ride height, thats the job of the springs!!!
capev86 is offline
Old 04-11-2006, 09:29 PM   #10
No, but if he's bottoming out over speed bumps, that tells me his shocks are shot.
Old 04-11-2006, 09:53 PM   #11
i dont bottom out over speed bumps, but the hitch bottoms out on parking stumps
2fst4u is offline
Old 04-11-2006, 09:57 PM   #12
What are parking stumps?
Old 04-12-2006, 04:06 PM   #13
the things that you back into or pull into to park...maybe a parking curb ??
2fst4u is offline
Old 04-12-2006, 05:08 PM   #14
Yep, you'll hit those, I do thats why I don't back in or if i do, I open my door and look or just pull straight in, its easier,
Money | Website Design | Bad Credit Loan | Bible shop | The Latest Gadgets
Page generated in 0.50153 seconds with 13 queries
