05-14-2006, 01:54 PM
My Ride: '88 Shelby Z TII
Putting the larger bar on the front will help with body roll up front, but it will also cause the car to push more. In order to balance the car out, then yes, it would be a good thing to put on the larger rear bar from the Shelb y car(the whole rear alxe), OR you could use the bolt-on Poly Bushings rear bar. THAT will make for a car the handles VERY well. I'd put on the smaller rear PB bar before I even considered the larger front bar. That will make more of a positive difference in the handling of the car. Combine that with a good alignment and it'll be night and day.
If you do decide to go with the larger bar up front, then you DEFFINATLY need the rear bar. Either the smaller or larger PB one with work fine, it just depends on how much twitchiness you can handle.
I DO NOT reccomned boxing the rear axle. While it IS effective, and it DOES work...it is highly unpredictable as far as how it will effect the handling of the car. It could cause a situation where extreme adjustment is required to make the car driveable. Trust me on this one...I know from first-hand experience.
