Old 11-18-2007, 06:59 PM   #1
Tire Question
My Ride: 1994 spirit
Engine: 3.0 v6
my 94 spirit originally has 195/70r14 tires on it. does anyone know if a 205/70r14 will fit? thanks!
seth959 is offline
Old 11-18-2007, 07:26 PM   #2
Re: Tire Question
My Ride: Shadow ES
Engine: 3 litre V6
Images: 6
Hi there.....is your model the ES...
as in 3 litre six engine w/4spd auto trans?
55trucker is offline
Old 11-18-2007, 07:29 PM   #3
Re: Tire Question
Engine: 3.0 v6
yes it is
seth959 is offline
Old 11-18-2007, 07:40 PM   #4
Re: Tire Question
My Ride: Shadow ES
Engine: 3 litre V6
Images: 6
Originally Posted by seth959 View Post
yes it is
Then I'm sort of surprised that seems to have 14" wheels on the car....doesn't the drivers side door sticker have a pressure rating for 15" tires attached to it?....ES cars had the optional 15's ...and they were of course...alloys........and I do have 205's mounted on my Turbostars
Old 11-18-2007, 08:03 PM   #5
Re: Tire Question
Engine: 3.0 v6
my bad, its not the es but it does have the 3.0, got mixed up
seth959 is offline
Old 11-18-2007, 08:35 PM   #6
Re: Tire Question
My Ride: Shadow ES
Engine: 3 litre V6
Images: 6
OK......I'm going to pick your brain here.....if you look at your ownership for the car.....look at the VIN# for the car......you want to look at the 6th digit in the serial number......it should be either a 1 thru 7(no #3 is used)...1 is economy, 2 is low line, 4 is high line, 5 is premium line, 6 is sport/special, 7 is performance.... 1 thru 4 will have 14" wheels ....5 thru 7 will have 15" wheels...
Old 11-18-2007, 08:49 PM   #7
Re: Tire Question
Engine: 3.0 v6
its a 4 so its a 14", do think 205's will fit? thanks for the help... if u couldnt tell, im a noob
seth959 is offline
Old 11-18-2007, 09:16 PM   #8
Re: Tire Question
My Ride: Shadow ES
Engine: 3 litre V6
Images: 6
There shouldn't be a clearance issue at all.....your wheels are.....steel?....14" steel wheels should be 5 1/2" wide. That width steel wheel, the max tire that the manufacturer would recommend is the "195". The 15" wheels (alloys) are 6" wide and the max tire that is recommended is a "205". I'm still wondering why you've got 14's on a carline that has the V6 engine...that driveline was used on the higher scale carline (LE, LS).
Old 11-18-2007, 09:29 PM   #9
Re: Tire Question
Engine: 3.0 v6
carline?
seth959 is offline
Old 11-18-2007, 10:31 PM   #10
Re: Tire Question
My Ride: Shadow ES
Engine: 3 litre V6
Images: 6
"Carline".......in your case...is "D" body...in that body style there are the different Series...(those were the six different numbers that I mentioned to you)...yours is the Highline...(#4).....that series did use the 14" steel wheels, but you've got a premium line (#5) driveline(V6 engine).... one that gets the larger wheels & tires (the 15's)...
Old 11-18-2007, 10:50 PM   #11
Re: Tire Question
Engine: 3.0 v6
is that strange to have a high line with a premium line engine?
seth959 is offline
Old 11-19-2007, 04:02 PM   #12
Re: Tire Question
My Ride: Shadow ES
Engine: 3 litre V6
Images: 6
I guess not so, to Chrysler.....perhaps the original purchaser ordered the car that way.....anyway no matter.....as far as your tires are concerned....you CAN get 205's on the 5.5" wide wheels....but take a good look at how far the sidewalls will be ballooned out. A 70 series tire will have a taller sidewall so there will be more room to flex, the smaller the sidewall (eg. 60series or 50series) the sidewall will have less flex and not be as happy on a thinner wheel.
Old 11-19-2007, 04:51 PM   #13
Re: Tire Question
My Ride: 2003 Dodge Neon SXT
Engine: I4 2.0
my uncle bought a '93 Acclaim that has the 14" steel wheels with metal wheel covers, and the 3.0 V6 and A604, so i guess it's not that uncommon.
~Ryan
sidepipe87 is offline
Old 11-19-2007, 07:55 PM   #14
Re: Tire Question
Engine: 3.0 v6
thanks trucker!
seth959 is offline
Myspace Proxy | Secured Loans | Mobile Phones | Myspace Layouts | Free phpBB forum
Page generated in 0.61458 seconds with 13 queries
