Old 11-25-2007, 07:14 PM   #1
Bigger bolt pattern
Mitsu Booster
My Ride: 1985 GLH-T
A friend of mine is performing a rear wheel drive conversion on his 90 Daytona, and was wondering if there is any way to use front rotors from the later Caravans with the 4.5" pattern? He's putting an 8 3/4 under the back end and would like to keep front and back bolt patterns the same.
Thanks.
lowblow is offline
Old 11-26-2007, 02:06 PM   #2
Re: Bigger bolt pattern
My Ride: 87 GLHS
It is possible to use the 5x120mm hubs from a caravan but that is more like 5x4.7" so it probably won't help...
-Rich
rfb6435 is offline
Old 11-26-2007, 06:03 PM   #3
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
-Rich
Its 5x114.3
speeduphoria is online now
Old 11-26-2007, 07:51 PM   #4
My Ride: 87 GLHS
Originally Posted by speeduphoria View Post
Its 5x114.3
Oh ok.. I remembered it incorrectly... The caravan is indeed 5x114 (5x4.5").
It would work best to start from a 91+ kframe in that case and use the spindles from a newer van. They are the same other than a slight difference on the tie rod connection. Or if you have the 91+ bolt in spindles already just buy the hubs for a caravan they will bolt right in.
-Rich
rfb6435 is offline
Old 11-26-2007, 11:15 PM   #5
Mitsu Booster
My Ride: 1985 GLH-T
Wow, that sure makes things easy. I'll pass along the info. Thanks alot!
Tom
lowblow is offline
Old 11-29-2007, 08:26 AM   #6
has anybody ever just unbolted the 3 bolts that hold the hub/bearing and swaped just this part?
22dodge is offline
Old 11-29-2007, 11:09 AM   #7
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
I put the Caravan front hub/bearing assembly on an 89-90 spindle on one of my Daytonas once to get a set of 4.5x5 wheels to fit. So they will bolt up to the 89-90 or the 91+ spindles with no problems. You obviously have to get a set of 4.5 van 11" rotors as well.
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Mortgages | Loans | Credit Card | 0 Credit Cards | Personal Loans
Page generated in 0.41693 seconds with 13 queries
