Old 01-01-2008, 03:00 PM   #1
90 tona swaybar to 93 tona ??
My Ride: 93 iroc daytona
Engine: v6-3.0
i got a 90 shelby big front sway bar in a swap and was considering swaping it into my 93 iroc v6 daytona. i know the lower control arms in my 93 are diff but can i swap the sway bars? thanks
jmitch is offline
Old 01-01-2008, 04:00 PM   #2
Re: 90 tona swaybar to 93 tona ??
SHELBY 16V !!!
lotashelbys's Avatar
My Ride: Lots of TIII cars:-)
Engine: 16V TIII
Feedback: (17)
Images: 1
No,they are slightly different. You will either have to use 89-90 A-arms and spindles or a 91+ sway bar in your 93.
~Jackson~
TIII GURU
91 Spirit R/T
91 Spirit R/T(GFs hotrod)
lotashelbys is offline
Old 01-01-2008, 11:54 PM   #3
you should be able to "tweak" it if needed. cliff ramsdell put a big bar with the 91+ k frame setup on his T3 wagon a few years back!
capev86 is offline
Old 01-02-2008, 03:44 AM   #4
Engine: v6-3.0
hmmmm it looks lie either the frame bushings would need trimming or the ends bent just a bit as its about a 1in off. are there any pics of Cliff's setup?
jmitch is offline
Old 01-02-2008, 10:48 AM   #5
SHELBY 16V !!!
Engine: 16V TIII
Feedback: (17)
Images: 1
Thats what I thought when I tried that years back. you would have to put the bar in a press and bend it slightly and then get sleeves put on the ends as the 89-90 bar is only 1" on the ends and the 91+ is 1 1/8
~Jackson~
TIII GURU
91 Spirit R/T
Old 01-03-2008, 02:36 PM   #6
Engine: v6-3.0
hmmm so i'm figring i'ld have to swap over to the stamped lower control arms and probably the 90 style crossmember as well.
jmitch is offline
Old 01-03-2008, 06:28 PM   #7
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
93 iroc should have the large bar if not the same size
xtrempickup is offline
Old 01-05-2008, 07:43 PM   #8
Engine: v6-3.0
its smaller than the 90 shelby bt the ends of the shelby bar are smaller than the ends of the 93 iroc bar.
jmitch is offline
Old 01-05-2008, 10:39 PM   #9
My Ride: TIII R/T
Feedback: (10)
Iroc should have had the heaviest duty suspension along with the Iroc R/T, i dont know the mm but someone should have that info
Old 01-18-2008, 04:07 AM   #10
Engine: v6-3.0
im curious. on the polybushings web site they talk about grinding the ends flat then drilling to use conventional sway bar end links. could i do this with the shelby bar?
jmitch is offline
Remortgages | Mortgages | The eBay Song | Mortgages | Mobile Phones
Page generated in 0.34527 seconds with 13 queries
