Old 01-14-2008, 08:23 PM   #1
my omnis plans
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
here are my plans for my new omni...
for the front im using the stock struts (there in great condition) and clipping my turbo van springs to put in the omni struts and lower the front by about 2"
then i have a CS sway bar to go in, and maby polly bushings down the road.
for the back... (i dont wana hear nay-saying till i see if this works) im taking out the rear struts and springs and replacing them with brand new steering dampers from a 4x4 (that bolt right in, in place of the struts), then ill stick a jack under it, jack it up to where i want it to sit, and weld up mounts on the axle to frame for the coil over short shocks i have from the back end of a jag.
then ill work in my vans 1" rear sway bar that i made for the van back in the day. oh ya, strut braces front and back as well. all in all, it should be preaty retaded! nice and solid. not the best way to it i know, but why not if i can use all existing parts instead of spending hundreds on "soon to be out of stock" koni stuff.
ill let you all know how it goes.
turbo minivan is offline
Old 01-16-2008, 01:01 AM   #2
Re: my omnis plans
pulled the struts and there not as good as they seemd, so im replacing them with new stockers, and i clipped my vans springs to go in them nice and low. also put in an 87 CS sway bar to replace the 3/4" joke of a sway bar that was in there! ha ha ha!
Old 01-19-2008, 07:08 PM   #3
Re: my omnis plans
i made and installed my rear "struts" and lowerd the car 4" all the way around. the rear end is AMAZINGLY solid. so solid that i dont even need to install my rear sway bar.
my rear struts are steering dampers with the lower spring perch of the old omni struts on them, the origional un cut springs on them, then bolted right in. the front is lowerd with new stock struts and clipped van springs, allong with a CS sway bar.
as hard as i try to rock the car side to side, i can barely move it 1 inch, and i can barely bounce it by jumping on the bumpers!! i havet driven it yet cause there about 5" of snow out side, but ill let you know how it handles when i do.
Old 01-20-2008, 03:11 PM   #4
Re: my omnis plans
ok, since i installed the new front struts and must not have the cam bolts lined back up as they were 100%, the car likes to slightly pull to the right if i let go of the wheel (steight as an arrow before) so without having to go get an alignmet (perferably), anyone have any tips on what way i should turn my cam bolt/s and on what side to make it true again? or maby ill just have to drive it, turn it, drive it, turn it, and test it like that. =(
Old 01-20-2008, 03:37 PM   #5
Re: my omnis plans
Turbo-Baron's Avatar
My Ride: 89 lebaron /shadow
Engine: 2.5 turbo
Images: 20
That car is going to be a beast.ANy pics?
Turbo-Baron is offline
Old 01-31-2008, 01:39 AM   #6
Re: my omnis plans
My Ride: 85 GLH
Engine: 2.5CB
i dont have any advice for you on steering, but my opinion on lowering a car--(sweet) but definately messes with the geometry of the front wheels, should get it aligned.
AND...
I WANT SOME PICS
sounds like a sweet deal, i want to lower my omni an inch ----cheap
ZachT is offline
Old 01-31-2008, 11:36 AM   #7
Re: my omnis plans
pics can be found here along with more detailed discriptions of stuff and other mods to date.
my horizon!!(hood pics!)
Old 02-01-2008, 12:15 AM   #8
Re: my omnis plans
My Ride: 85 GLH
Engine: 2.5CB
DUDE!!!!, i looked through that thread of yours and the pics didn't work, i want to see them, any way you can load them on this site at all or something?
thanks
zach
ZachT is offline
Old 02-01-2008, 10:54 AM   #9
Re: my omnis plans
i can e-mail you some. im too computer illiterate to post pics on this site.
PM me youe e-mail and maby you can post some for me??
Old 02-05-2008, 09:23 PM   #10
Re: my omnis plans
ZachT, did you ever get my pics? post em up dude!
Ayuda informatica | Servidores | Myspace Layouts | Car Loan | Christmas Lingerie
Page generated in 0.48798 seconds with 13 queries
