01-21-2008, 12:39 AM
Re: Bigger front brakes
you need 91+ parts to work with those 91 spirit knuckles. the 89 daytona shelby pieces have the caliper bracket as part of the knuckle (basically the same setup though). unless you can score on spirit/daytona or 91+ shelby/iroc 11" brakes, there is an alternative. find an early 90's caravan with 15 inch rims and the larger bolt pattern (not our 5x100mm). you just need the calipers and brackets....they will bolt to your spirit knuckles. you will need to buy rotors for an 89+ daytona, 91-92 spirit, etc with the big brakes. the caravan brakes are the same exact pieces, just the (91+ bolt on hub) has the wider bolt pattern!
