Old 01-23-2008, 10:14 PM   #1
92 daytona manual rack conversion?
My Ride: 92 Daytona Iroc R/T
Engine: 2.4 T-III
has anyone done this? i have the rack from a 87 daytona reman but i heard that you need a new steering shaft coupler? any info welcome
chuck
Chucksrt is offline
Old 01-23-2008, 10:36 PM   #2
Re: 92 daytona manual rack conversion?
My Ride: 91 Daytona
Engine: 2.4
i read this on a honda forum, and just drained the fluid, removed the pump and cut the lines on the rack, all of them, as long as youre not pushing the fluid around while steering, it works like a manual rack, i havent had any issues yet.....
Rock Kustoms is offline
Old 01-24-2008, 12:40 AM   #3
My Ride: 1991 Daytona CS
Engine: 2.5 ltr
If you have a Reman manual rack, the coupler going up to the steering column is different, I have been told that there are at least 3 different manual rack couplers (size and spline difference), There is a neon manual coupler that is a recall part (thousands still available), and if it has the same spline count you can take the two couplers apart and mate the together (the lower manual neon coupler and the factory PS upper coupler) I have done this a few time and not really that hard just takes some time and tools. if you need any specific info let me know, Hope this helped.
slowbrokedodge is offline
Old 01-24-2008, 12:42 AM   #4
Engine: 2.5 ltr
But if you do that you fail to see that there is a different ratio between the two and the manual rack will be easier to steer with.
Old 01-24-2008, 07:24 AM   #5
My Ride: 91 Daytona
Engine: 2.4
true, theres an easy ratio and hard ratio of both, i think the power racks are 14:1 and 18:1 and the manuals are 18:1 and 22:1. 2.5 turns lock to lock is the easier ratio for power rack, and seems to work well
Old 01-24-2008, 02:32 PM   #6
professor chaos
dragbaron's Avatar
My Ride: '88 Lebaron GTC
Will I run into the same problems on a shadow? I thought you could just buy a manual rack and it would bolt right in to the column.
88 Lebaron GTC- T2/auto
91 Spirit R/T (finally got one!)
72 Plymouth Duster-440 project (someday)
68 Plymouth Barracuda Formula S- 340/4spd (runs better than it looks!)
dragbaron is offline
Old 01-24-2008, 04:00 PM   #7
Engine: 2.5 ltr
The spline on the manual rack is much smaller and will not just bolt up.
Old 01-25-2008, 08:05 AM   #8
Engine: 2.4 T-III
thanks for the help i will be getting back to you if i run into any problems. Do you know what year neon i should look for?
thanks,
chuck
Chucksrt is offline
Old 01-25-2008, 08:10 AM   #9
Engine: 2.5 ltr
The neon only had a manual rack one year and that was 1995, so that may be hard to locate used, but if you go to the dealer they should be able to locate the parts you need.
Old 01-25-2008, 11:03 AM   #10
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
You can try the dealer or boneyards if you want to - I struck out on that 2 years ago. So, I made my own - here's the details - Manual Rack Coupler Thread
Shel-Game is offline
Mobile Phones | MPAA | Gavin Newsom | Loans | Mortgages
Page generated in 0.55360 seconds with 13 queries
