Old 01-27-2008, 03:36 PM   #16
Re: Why won't the poly busnig fit???
GTCUL8R
Polygon's Avatar
My Ride: 1989 LeBaron GTC
Engine: Turbo II 2.2L/135ci
Images: 59
Well, this is bothersome as I just bought a set for my GTC. Mine is the 1 1/4" bar with 1 1/16" endlinks.
Did you what size endlinks did you tell Johnny you had?
I would just use some washers. Also, would there be anything wrong with shaving it.
My CarDomain Garage
Polygon is offline
Old 01-27-2008, 07:10 PM   #17
My Ride: 85 GLHT, 87 ShelbyZ
GREAT PICS TRYINGBE!
I just found a pic of Johnny's bar with his bushings when I was trying it in my car. Not the best pic, but you can see that this is the way the bushings are supposed to go in with the rib to the front of the car and you can see the gap I was going to have to run (with spacers of course) to get the bar to rotate freely. 100_0405
I like my ES d-shaped brackets much better.
GLHNSLHT2 is offline
Old 01-27-2008, 07:36 PM   #18
Feedback: (32)
Where can I find me some of this? That would solve my problem, fast and easy.
07-28-06_2024
tryingbe is offline
Old 01-27-2008, 08:13 PM   #19
My Ride: '88 Shelby Z TII
Man, I swapped to a PB 1.25" bar on a '91 K-frame with cast A-arms a few years ago. I don't remember having this problem at all!!!
Reaper1 is offline
Old 01-27-2008, 08:30 PM   #20
07-28-06_2024
Energy Suspension Sway Bar Bushings: ENS-9-5113R - summitracing.com
For Red
Energy Suspension Sway Bar Bushings: ENS-9-5113G - summitracing.com
Black
I had to notch out the slots on the ends (easy) cause they're a hair to short overall, and then got some metal stock from Lowe's or Homie Depot and cut to length and holes drilled in the right spots and bolted them up. Think it's 3/16th's thick. The thicker the better. I've seen them start to bend if too thin.
Old 01-27-2008, 09:06 PM   #21
Feedback: (32)
Time to check local autozone to see if they have it stock, thanks.
tryingbe is offline
Old 01-27-2008, 09:13 PM   #22
Feedback: (32)
For K-frame, years make a huge difference.
tryingbe is offline
Old 01-27-2008, 11:27 PM   #23
but the 89+ kframes are supposed to be identical.
Old 01-28-2008, 12:26 AM   #24
My Ride: 86 Turbo Relaint Wag
Engine: 2.5 turbo
Anyone have a stock factory 1989 style bushing they can photograph next to a Energy Suspension one or a PolyBushings.com one?
Johnny Spiva
Johnny is offline
Old 02-01-2008, 07:42 PM   #25
GTCUL8R
Polygon's Avatar
Images: 59
Johnny Spiva
I could since mine just arrived the other day, thanks a ton! However, I won't be able to get the stock ones off until Spring.
My CarDomain Garage
Polygon is offline
Old 02-01-2008, 08:12 PM   #26
Engine: 2.5 turbo
Spring? Isn't that this weekend?
Johnny Spiva
Johnny is offline
Old 02-01-2008, 09:29 PM   #27
Spring is the 20th of March.
Old 02-01-2008, 09:40 PM   #28
Engine: 2.5 turbo
I know!
But pretend it's this weekend.
Johnny
Johnny is offline
Old 02-02-2008, 12:12 AM   #29
well if it's anything like it is here there's no way. We have over a foot of snow on the ground, there's 4ft around my shop where it slides off the metal roof and piles up on the side. It's so slick going up the slight incline to get out of the back yard and through the fence I got my g/f's liberty stuck in 4wd Lo for a little bit. Course the tires are down to the wear bars on it but still. No spring around here for a while. I predict that the Groundhog will see his shadow and it'll be another 6wks of winter.
Old 02-02-2008, 12:17 AM   #30
GTCUL8R
Polygon's Avatar
Images: 59
Yep, there's over a foot of snow on the GTC right now. Even if it were the right weather I won't be able to do any car work for about a month.
My CarDomain Garage
Polygon is offline
Mortgages | Car Credit | Current Accounts | Credit Cards UK | Gas Suppliers
Page generated in 0.41858 seconds with 13 queries
