03-09-2008, 12:06 AM
#16
Re: Suspension Questions
My Ride: 1989 Daytona ES
Engine: 2.5l Turbo
Cindy has them for a decent price
03-09-2008, 12:50 PM
#17
My Ride: 1985 shelby charger
Has anyone tried the LRE l-body lowering springs? They sound a lot like the mopar autocross springs. Anyone have pics of them on a shelby charger?
03-09-2008, 03:57 PM
#18
My Ride: '84 GLH, '04 R/T
Engine: 2.2 HO, 2.0 Magnum
The LRE are a lot stiffer than the old Mopar Autocross springs. The 1'' drop is perfect for the street, not too low but still looks great!
03-09-2008, 05:00 PM
#19
Are they a good spring for the street or are they TOO stiff? Whats a good spring rate for an aggressive DD?
03-11-2008, 01:33 AM
#20
FWDperformance.com has the adjustible Koni coil overs with adjustible Eibach coils in one kit. Buy all the poly for the car, engine and suspension. I like the 1 1/8" front bar and 1" rear bar. I am cutting down a twin tube DC strut brace for the rear of an SRT 4 and using it in the front of my GLHS. The rear is a swing arm suspenion, so unlike most imports the TDs don't need a rear bar. Alignment is huge. I like 1 negitive up front with zero toe and poly bushings. In the back I like .5 negitive and 1/16 toe in. Alignment shops will destroy your handling by adding positive camber, you have to find some one to align the car to your specs. Not what there POS computer says to do. With positive front camber and negitive rear camber the cars under steer bad or plow straight in a corner.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
03-11-2008, 01:35 AM
#21
you can't buy konis to use the LRE springs now, so the car could bound and bounce with them and GR2s
Rob Walsh
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
03-11-2008, 07:37 AM
#22
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
03-11-2008, 11:55 AM
#23
OMG no, do not read dempseys page. A freind of mine wrapped his L body around a mail box (concrete) by running too big of a rear brake and not enough front. You DO NOT stick 11.44" vented rear disks on a L body or any other TD without using the 11" fronts, period. Want to learn about the SLH packages go to boostedmopar forum and look it up.
GR2s are best for a performance street that won't beat you up. I run them on my wagon, a Masi TC and a mini van.
Sensatrac how ever you spell that lol, they are junk like putting on wasted shocks and they don't last. But are the softest you'll get with some control.
The full Koni coil overs from FWDperformance.com, they have GR2s as well. Dempseys page is about 10 years old and was real nice back them. But is out dated and the SLH section isn't that safe. I actually met Dempsey in Vegas during Mopars at the Strip. Real nice guy, loaned me a granger valve for a tire dyno run. But my $60 pick in pull engine on 3 pistons and 14 PSI of boost didn't want to make over 214 WHP and 264 ft lbs lol. dempsey did pretty well drag racing his van that week end. My GLHS made it to pg 76 of the Jan 04 Mopar Muscle mag in the dyno section. in the mag on the MP stage 2 computer controlling boost to 13. The GLHS had 76 PSI compression in one hole. 204 WHP at 4,400 RPM  I think Dempsey won the $250 for FWD class.
Rob Walsh
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
03-11-2008, 12:28 PM
#25
In a stock GLHS with mini fronts you get some nose dive. Picks up the rear end too much coming into corners. The rear disks let the car come into a corner more flat. SLH 1 is basically turbo level of brakes. SLH 2 should be mini fronts and bigger drums. SLH 3 should be mini van fronts and 10" solid 89-up rear disks. SLH 4 is 4 wheel vented 11" brakes like on my GLHS. I know that much of the braking is on the nose. But weight transfer has a ton to do with it. When you have rear disks they are hooked to a swing arm that compresses the suspension under hard braking. So the rear of the car sits down, removing weight transfer and the rear tires are doing more. Not to mention your not entering a corner with the butt of the car in the sky.
Rob Walsh
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
03-11-2008, 09:40 PM
#26
I hadn't looked into it that much, I found it probably about 6-7 years ago and hadn't read it since.
Just because he has one bit of information wrong doesn't mean someone shouldn't read his page.
Now that I've been scolded like a 2nd grader, I shall proceed to sit in the corner, all alone, sucking my thumb and sobbing loudly.
03-11-2008, 09:46 PM
#27
TurboDodge.com Admin
My Ride: 87 CSX & 85 GLH
Engine: 2.2TII & 2.5N/A
Koni's for L-Bodies are still around, check out Cindy's site...
-Clayton Dennis ~ Forum Admin
1987 Shelby CSX #674
1985 Dodge Omni GLH
03-11-2008, 10:05 PM
#28
They're coilovers... $1049 for all of it. They won't work without the rest of the stuff.
03-15-2008, 12:25 PM
#29
My Ride: 1989 Lancer Shelby
So there aren't any affordable decent struts anymore? I'm getting eibachs all around and gas-a-just on the back. All I need is a decent pair of struts but it seems nobody makes any good ones anymore hehe
03-15-2008, 02:10 PM
#30
Still the best you can buy and available...
1985 Dodge Omni GLH
Currently Active Users Viewing Th | |
