Old 03-15-2008, 08:33 PM   #31
Re: Suspension Questions
The Pope's Avatar
Originally Posted by sittn86 View Post
Now that I've been scolded like a 2nd grader, I shall proceed to sit in the corner, all alone, sucking my thumb and sobbing loudly.
I am an A hole about the SLH write up because it'll kill you done wrong. The 54mm front brakes and 10" rear solid disks are a lot more front strong than Dempseys setup. Yet a friend could have died buy running 10" solids without mini van fronts. L bodys are just too nose heavy, sorry I was so loud, just making sure people heard me in the back
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
70 R/T SE Challenger
The Pope is offline
Old 03-15-2008, 08:34 PM   #32
The Pope's Avatar
Originally Posted by Mudman View Post
So there aren't any affordable decent struts anymore? I'm getting eibachs all around and gas-a-just on the back. All I need is a decent pair of struts but it seems nobody makes any good ones anymore hehe
I would be very happy with gas adjust on all 4 corners. But talking KYB into it may be tough
Rob Walsh
86 GLHS 76
87 GLHS 306
89 CSX 187
89 turbo mini
The Pope is offline
Old 05-10-2008, 09:23 PM   #33
My Ride: CSX-T
Engine: 2.2 T1
Images: 1
Okay you wisened technicians of turbodom. How does all this aply to P bodies?
What is the ultimate handling set up for these cars?
ljbprrfmof is offline
Old 05-12-2008, 11:55 AM   #34
GTCUL8R
Polygon's Avatar
My Ride: 1989 LeBaron GTC
Engine: Turbo II 2.2L/135ci
Only a little. The L body is a completely different animal than the other models. You won't be able to get Konis, not new anyhow. Also, don't use Eibach springs with the KYBs unless you want a horrible ride.
As for the OP, someone is working on adapting Neon coil overs to our cars. You might want to hold out and see how that goes.
Clint: 1989 LeBaron GTC Turbo II - 1991 Dodge Stealth R/T TT - 1989 LeBaron Premium Parts Car
My CarDomain Garage.
I am looking for gray interior trim for a J-body (1987-1989) LeBaron coupe hardtop. If you have anything please PM me before throwing it out.
Polygon is offline
Old 05-20-2008, 05:34 AM   #35
My Ride: 85 Shelby Charger
Engine: 2.2L turbo 1
Originally Posted by 1984Rampage View Post
Im talking about my shelby charger. The rampage in my screen name is my project car. But for my charger whats a good spring rate and where can I get these springs?
You can go to FWD Performance and get those old LRE,lowered autoX springs, I believe the spring rate are 180 lbs/in front and 145lbs/in rear, that's really not that high of a spring rate and the KYB's should work fine. I thought that the front autox spring was 240 lb/in, but all I found in the 2.2 speed secrets was 180 & 145 lb/in!
vader85 is offline
The eBay Song | Loans for people with bad credit | Internet Advertising | Free Advertising | Loans
Page generated in 0.30819 seconds with 13 queries
