Old 04-25-2008, 05:11 PM   #1
cant get wheel spin noises in 2nd at 248whp
My Ride: 90 Daytona ES
Engine: 2.5 Turbo 1
90 daytona es 2.5 turbo
dynoed it at 248whp / 300 wtq
rapid shifting at WOT from 1st to 2nd almost never makes any audible noise.
feels like 2nd hooks HARD (actually very nice)
in first at WOT right after I drop the clutch from about 3k it feels like something is slipping..maybe clutch, maybe tires..whatever it is it doesnt make noise, just feels like i am momentarily driving over gravel....probably tires spinning then huh..why are they so quiet?
suspension is probably 17 years old
SO..my questions are:
if this car were new, but had these power levels, what WOULD i experience as far as wheel hopping/wheel noises/burnouts
what should i replace to optimize this car for 1/4 mile drag races?
power and torque levels will be increasing shortly to mid 300's
acannell is offline
Old 04-25-2008, 06:43 PM   #2
Re: cant get wheel spin noises in 2nd at 248whp
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
if you think the clutch may be sliping put it in 4th at lower rpm and hammer it, it the rpms rise then its sliping
speeduphoria is offline
Old 04-25-2008, 06:51 PM   #3
My Ride: 1989 Daytona C/S
Engine: 2.5 T1
tires don't squeal unless they aren't spinning that fast. It usually isn't any more audible than a muffled roar.
RGHoskins is offline
Old 04-25-2008, 08:57 PM   #4
My Ride: '89 Daytona Shelby
heh ... or in fifth up against a tree. Motor dies clutch good.
puppet is offline
Old 04-25-2008, 10:24 PM   #5
My Ride: 85 GLHT, 87 ShelbyZ
Hooking is a good thing. you have good suspension?
GLHNSLHT2 is offline
Old 04-26-2008, 02:12 AM   #6
My Ride: 88 daytona pacifica
Engine: 2.2, t3/t4 fmic
watch your speedo it will tell you if it is spinning if it jumps, if it does not jump then probably clutch is slipping
88jbody is offline
Old 04-27-2008, 07:47 AM   #7
Frankenstein Builder
oklamopar's Avatar
My Ride: 2002 R/T 2003SRTs1
Engine: 2.0l HO & 2.4l Turbo
my car does the same thing. i had someone drive beside me and they told me it was spinning. they saw a little smoke. pulls like mad. i also only run cheap $80 a piece tires,
Mopar Or No Car.
2002 Neon R/T "Blackula" http://www.cardomain.com/ride/282176
2003 Neon SE (srt-4) "Frankinstein" http://www.cardomain.com/ride/2480295
1969 D-100 http://www.cardomain.com/ride/2935139
oklamopar is offline
Old 04-27-2008, 01:10 PM   #8
Engine: 2.5 Turbo 1
i have no idea what condition the suspenion is in, for all i know its original and 17 years old
acannell is offline
Old 04-30-2008, 08:53 AM   #9
Garrett Booster
My Ride: 87 Shelby Charger
My old sundance turbo with performance computer and open exhaust would never spin when dumped into second gear for some reason too.
Berubeny is offline
Old 04-30-2008, 05:33 PM   #10
My Ride: 86 shelby charger
something was wrong cause my basically stock 86 sc will do a 30 ft posi dumping it from a roll in second and the travel in the clutch pedal is about to its end and still wont slip
bgbmxer is online now
Old 05-18-2008, 06:00 PM   #11
My Ride: 91 shelby daytona
kinda old thread but my 91 (doesnt have quite that power yet) does the same thing. I Know the tires are spinning when i hammer on it but i can never hear a difference. The engine itself is too loud i guess. Much louder than my 92 iroc was for some reason. Just sounds more airy... (best way i can describe it) I was assuming that the control arm bushings must have been replaced as well which would aid in the smooth wheel spin.
Powell is offline
Optical Illusions | Web Advertising | Problem Mortgage | Homeowner Loans | Loans
Page generated in 0.37653 seconds with 13 queries
