Old 05-16-2008, 05:42 PM   #1
Thumbs up ---independent REAR suspension---
NORCAL
86trbolancer's Avatar
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
Feedback: (6)
Images: 32
Has anyone ever tried to do an independent rear suspention setup on one of there TDs????
I really like the ride of having 4 wheel coil-overs, and being able to raise and lower your car when you want...Not to mention the handling that it gives you.
I was thinking of maybe even going all out and tring to take a 4ws(4-wheel-steering) model of some early honda prelude and making a 4ws LANCER!!!!! It would give me the suspention that i want. And would be hella custom!!!
I know that there is manual racks in the earlier models, and motor driven racks in the later years. Not even sure where i'd start with looking into it......
Lets get the topic started!!!!!
TIA
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
86trbolancer is offline
Old 05-16-2008, 06:38 PM   #2
Re: ---independent REAR suspension---
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (9)
it has been done, im pretty sure that the BSX owned by Brian Slowe has a Neon coil over modified rear suspension in it
xtrempickup is offline
Old 05-16-2008, 08:26 PM   #3
My Ride: 85 GLHT, 87 ShelbyZ
it's pointless in a FWD car. Nissan put IRS in the maxima then went back to a twist beam because it isn't needed in a FWD car. You can do rear adjustable ride height springs in the back. It's easy and works. But trying to do IRS is a lot of work for nothing. Now if you were driving the rear wheels fine. But you're not so don't worry too much about them. You don't want the rear to stick to much. It needs to slide more than the front.
GLHNSLHT2 is offline
Buy Anything On eBay | Secured Loans | Car Insurance | Mortgage Calculator | Brazilian bikini
Page generated in 0.51269 seconds with 13 queries
