Old 05-27-2008, 10:04 AM   #1
Who's tried P-body front suspension on a L-body?
My Ride: 84 Rampage
Will the knuckles bolt to the lower control arm? Are the struts adaptable to the l-body top mounts like the neon swap? I have an 88 shadow with fairly new parts I'd like to swap if possible and put the 15" crab whells on my Rampage.
Am I way out of it with this idea?
Couldn't really find anything w/search.
OrangeJbird is offline
Old 05-27-2008, 02:45 PM   #2
Re: Who's tried P-body front suspension on a L-body?
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
Una did a website blog of his G body bits into his 2.4 'rizon RT
(G body bits same as P body)
detobias is offline
Old 05-28-2008, 02:10 PM   #3
i used 1985 caravan knuckles and a frames on a 1985 charger.
allmotor is offline
Old 05-28-2008, 04:46 PM   #4
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
My old GLH had '90 VNT k-frame and front/rear disc brakes.
'01 Maxima SE
Will Martin is offline
Old 06-12-2008, 11:46 PM   #5
My Ride: 88J 94P 03dime
Engine: 2.2 in all of em
i just went through a lot of this on my lebaron. had to replace front k-frame cause it had several large cracks in it. look up K-frame in this forum- you'll find all the info you need.
crusty shadow is offline
Business Credit Cards | Loans | Loan | Western Union Money Order | Northern Rock
Page generated in 0.30855 seconds with 13 queries
