Old 06-01-2008, 08:08 PM   #1
Sandblasting, Things to look for?
My Ride: 89Daytona/99Mustang
Engine: 2.2L Turbo II/3.8 V6
While im cleaning up my suspension, (replacing shocks/struts/springs/bushings/mounts ect) Ive noticed that the wheel hubs are a bit more on the rusty side than Id like. I wanna sandblast the assembly but Im unsure if I could damage the wheel bearings (cramming them with sand?) in the proccess. Is this something I have to worry about? I will be getting the swaybar sanded by hand and painted w/ruberized undercoating then sprayed w/ bumper paint(flexable enough to go over the rubberized coating).
scorpion1 is offline
Old 06-01-2008, 09:33 PM   #2
Re: Sandblasting, Things to look for?
My Ride: '89 Daytona Shelby
Why not use rust bullet. You should be able to wire off the loose stuff then coat. Leaves a powder coated "feeling" finish. Supposed to stop the rust in the process.
puppet is offline
Old 06-01-2008, 09:56 PM   #3
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
I'm not sure about painting over rubberized undercoating. Also it will wear off where it contacts the bushings.
speeduphoria is offline
Old 06-01-2008, 10:38 PM   #4
TurboDodge.com Admin
moparfwdsleeper's Avatar
My Ride: 87 CSX & 85 GLH
Engine: 2.2TII & 2.5N/A
Feedback: (29)
Images: 166
pull bearings, blast, coat, replace bearings, install... easy to me
-Clayton Dennis ~ Forum Admin
1987 Shelby CSX #674
1985 Dodge Omni GLH - Parting Out, PM me!
moparfwdsleeper is offline
Old 06-02-2008, 09:00 AM   #5
"pull bearings, blast, coat, replace bearings, install... easy to me "
hehe, Ive never done it before I wasnt sure if they were sealed or exposed/multiple pieces. If I can get the bolts out Ill probably go this path, thanks guys!.
Old 06-04-2008, 09:29 AM   #6
BobD's Avatar
My Ride: 1987 Shelby GLHS
Images: 6
The problem with sand blasting is the sand "will" get in places you don't want it to get in to. Is this for a 89+ Daytona? If so, I'm guessing you've already removed the hub assembly from the spindle? I know around here, the hub assemblys are like $8.00 at a salvage yard. If you wrapped the bearing section really well and taped the heck out of it, and then blasted it outside of a cabinet, you may be OK. Try to do as little blasting as possible and aim away from the taped bearing area. But then again, the sand goes where it wants to go. I don't know what pressing an old bearing out is like. Most of that's hidden in the wheels so that's a plus. The only time it will be seen is when you're working on the car.
Bob Doherty............ MNSDAC Website
Coon Rapids, MN...... Car Pictures Mine and Friends
'87 Shelby GLHS #784
'87 Shelby GLHS #654
'87 Horizon 45,000 actual
'89 LeBaron GTC Convert TII
'94 Sundance2.5 auto
'68 AMX #5816
SDAC Member.expires 3/2009..MNSDAC Vice President
BobD is offline
Old 06-05-2008, 01:40 PM   #7
well I will be upgrading to Motegi Traklites so most of it would be exposed. Im just trying to clean this car up whilst fixing it up lol.
Credit Card | Cheap Car Insurance | Buy Cell Phone Only | Loans | Loans
Page generated in 0.31431 seconds with 14 queries
