Old 06-26-2008, 01:12 PM   #1
Rims for my rampage? 4-lugs?
My Ride: 1984 Dodge Rampage
Alright I just want to know what wheels will fit on my rampage, I am looking for some but all I can find is stock wheels or ugly 14s or 15s for it. I'm not looking for 17s and 18s, but I want a 16 Inch wheel. Either way, what the heck will fit, those stupid 4-lugs!!!!! AHHHHHHHH
Help me out...
I know the Omni's use 4 bolt wheels but is everything else the same on them? If thats the case than it should be easier to find my 16s
Hemizach is offline
Old 06-26-2008, 01:24 PM   #2
Re: Rims for my rampage? 4-lugs?
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
Images: 14
Doesn't Honda (sorry) use the 4x100 bolt pattern?
ol"blue is offline
Old 06-26-2008, 01:41 PM   #3
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
I have Mazda RX-7 wheels on my Rampage:
'01 Maxima SE
Will Martin is offline
Old 06-26-2008, 02:18 PM   #4
I'm not sure, what else would I have to worry about besides the bolt potten though?
Hemizach is offline
Old 06-26-2008, 02:28 PM   #5
Engine: 2.5 T2
Images: 14
Mainly back spacing. Not enough and you hit the fender, too much and you hit the struts.
ol"blue is offline
Old 06-26-2008, 04:01 PM   #6
This is going to be yet another stupid question. but does the omni have the same specs?
Hemizach is offline
Old 06-26-2008, 04:03 PM   #7
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
OMG there are like a thousand different rims with the 4x100 bolt pattern and a FWD offset that will work on an L-body , or K or EEK or G or H or S or P or .....
pretty much any manufacturer's FWD 4 bolt rim will work they almost all run 4x100 and a decent offset
detobias is offline
Old 06-26-2008, 04:55 PM   #8
amen to that. u could go to Tire Rack - Your performance experts for tires and wheels to find some more info.
omni is exactly the same as rampage and charger and first year daytona and first 2 years of minivan. 100mm x4. i have 2 15" 4bolt pizza wheels that came off an omni glh non-turbo, so theres a guaranteed fit to the rampage. go on ebay and surf around, u can find a lot of 100mm x4. i'd stay 6.5" max width just to be safe.
allmotor is offline
Old 06-26-2008, 04:58 PM   #9
Politically Incorrect
Screamin4banger's Avatar
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
I know the older ones did. When I went off-roading one Saturday night (long drunken story) I needed to replace some 13" rims on my 86 accord. I slapped a couple from a Turismo on it and went on with life.
Screamin4banger is offline
Old 07-22-2008, 08:42 PM   #10
You have to pay attention to the hubcentric bore. I just bought a set of Honda wheels, and they are just barely too small.
Omni/Horizon bore is 57.1mm, the Hondas are 56.1mm.
QwikSRT4 is offline
Old 07-22-2008, 09:04 PM   #11
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (10)
factory honda wheels you may have to watch for, aftermarkets probably not an issue
xtrempickup is offline
Loans | Loans | Advertising | Mortgages | Mortgage insurance
Page generated in 0.38600 seconds with 13 queries
