06-27-2008, 02:50 AM
Steering problem in '88 shelby z
My Ride: '88daytonashelbyz
Engine: 2.2L I4
Hi, i've got this problem with the steering and i was wondering if anyone had any suggestions. I've had an alignment done recently, replaced worn passenger steering knuckle and lower ball joint, and the steering rack's tight. When im driving and reach any sort of power, most nocticeably this happens under around half throttle application reachign 3000ish rpm, the car will go from steering perfect straight, and it lurches over, with the steering wheel ending up about 30degrees west of north, and the car still moving in a straight line. If you let off the throttle at this point the car will "lurch" back to having the wheel centred again driving perfectly straight. We've checked the motor mounts thinking that would be a good guess, but they're fine. If anyone has any idea at all on what this could be, i'd be very grateful for the help. The car is drivable like this, but its difficult when driving hard, and letting off between shifts and having the car "lurch" around on me. Please help!
thanks
