06-29-2008, 01:49 AM
Re: 215/40 r17 vs 205/40 r17 tire sizes
Politically Incorrect
My Ride: 85SC/86SC/91RT/73SE
Engine: 2.2/2.2/2.2/6.6
well, 10mm from sidewall to sidewall and 8mm difference in diameter
40% of 215 = 86
40% of 205 = 82
so, 8mm difference in diameter (assuming same tire brand, style, tread depth, etc))
... and each tire mfg will give you the rim width range for each of their tire sizes per style. if you are looking for tight handling, you want the widest rim for that size you can fit.
for example, if you have size 'a' and size 'b'...
and the book lists something like: 'a' is 5.5" - 7.5" and 'b' is 5"' - 7"
and you know you are going with a 7" rim, using 'B' on the 7' rim will be tighter handling than 'a' on the same rim even though you might think the wider tire will handle better...
if that makes any sense?
I could find a better way to say it
