06-29-2008, 10:25 AM
steering wheel off-center, no pulling though
My Ride: 90 Daytona ES
Engine: 2.5 Turbo 1
90 daytona es
was driving downhill and flooring it, bottomed out and then shot up, causing wheels to drop and pull apart drivers inside CV joint, letting the rollers and needle bearings fly apart all over the road
anyways, replaced axle
now if you point the car straight on the freeway, wheel is off center. didnt do that before. car does not PULL though...it will go straight without touching the wheel, its just off...
pointing the wheel straight makes the car turn left.
NOTE: axles are not the same brand left/right anymore...they weren't before though either, but its a DIFFERENT mismatch now
what should i check?
