07-11-2008, 06:15 PM
Re: Front Suspension question
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
its probablty sitting lower and bottoming out on the bump stops (internal to the strut)
if the struts are shot too I'll bet its a ruffrider
coil springs are very common ; the G body interchanges with the P H AA K EEK etc (AFAIK - if incorrect someone please jump in)
the Z would have had stiffer springs from the factory ; look for another z (obviously) for perfect interchange, or you could certainly run softer springs (from a non Z) if you chose too, with a subsequent decrease in handling
you can also buy aftermarket (stiffer) springs
any good spring shop should be able to get these new also
