Old 05-18-2003, 12:55 AM   #16
what about running no pump period? the pump i was putting back on after my rebuild kept fighting me trying to go in, so i just unkooked the 1 line i managed to hook up, and threw it across the garage and dented the crap out of it. lol. so i just hooked the inlet/outlet hose together. the pump was (and has been) dry for awhile. so if this rack dies whiile i own the car, is there a non-powering steering rack that will fit the g-body?
BuRn__ is offline
Old 05-22-2003, 09:45 PM   #17
getragguy
If you really wanted to keep it but not use the belt you could purchase a highrpm electric motor and run it off of that.
Does anyone know how this is possible, it sounds like a really awsome idea.
Old 05-22-2003, 11:04 PM   #18
power steering systems push between 1-2000 psi. the kind of pump youd need to run it would probly draw enough amps to make it not worthwhile.
Vigo is offline
Old 05-22-2003, 11:40 PM   #19
My Ride: 1985 Dodge GLHT
Engine: 2.2 T1
Hey..... Who needs power steering?
I used to own a 1986 Honda Civic (No jokes please) that had no power steering, and it steered fine. It weighed about the same as my GLHT, which currently has no power steering- bad belt. I would much rather leave the belt off anyways since it just takes power away from the motor.
Dodgeglht is offline
Old 05-23-2003, 01:33 PM   #20
just take the pump out like i did
BuRn__ is offline
Old 05-24-2003, 02:07 PM   #21
does it work alright with the inlet outlet hoses hooked together? will the rack last hooked up that way if you fill up the hoses with fluid?
turbododge89 is offline
Old 05-24-2003, 06:21 PM   #22
car hasnt ran since january, so i cant offer any advice on that setup yet tho. BUT...my old pump was busted and it was dry anyway, so its pretty much the same thing, just w/o the pump. some say the rack wont last, others say theirs has lasted forever. i guess ull find out eventually. lol
BuRn__ is offline
Link Vault | Plane Tickets | Remortgages | Cadillac | Meeting Rooms
Page generated in 0.32035 seconds with 13 queries
