Old 08-03-2008, 08:07 PM   #1
1987 LeBaron Rear Hub Assembly
My Ride: 1987 Lebaron
Anyone know where I can get these?
I went to do the rear brakes and the drums wouldn't come off the hub; no matter how much hammering or heat I threw at it.
I guess the drum having a rust hole right through it is an indicator of how long this had been sitting and most likely not removed in a while either.
No one (3rd Party Parts Vendors/Stores) shows a rear hub assembly part available.
Next step is to call the dealership... but there's got to be an easy/less expensive answer.
Thanks in advance,
scarello - RI
scarello is offline
Old 08-03-2008, 08:53 PM   #2
Re: 1987 LeBaron Rear Hub Assembly
hotrodguru
dirtyglhturbo's Avatar
My Ride: 86 glh turbo
Engine: t2 2.2l intercooled
the studs need to be pressed out and then you can replace the drum. anyone with a press can help you. i have seen others press out the studs, press them back into the hob, and then drill the new drum holes just slightly bigger, so the replacement will slip on and off without bearing removal. . enjoy
dirtyglhturbo is offline
Old 08-03-2008, 08:54 PM   #3
hotrodguru
and you are right, no one except chrysler will have a new hub for you, but you shouldn't need it unless you trashed it. unlikley though
Wedding Gifts | Loans | Car Loan | Car Loan | Car Loan
Page generated in 0.39288 seconds with 13 queries
