Old 08-15-2008, 10:38 AM   #1
Clingy Clanky Front end on Turbo Mini
Ok - Here is another one...
When I am hitting little bumps on the side streets, the front end sounds like it is rattling apart... its really annoying. Sounds like clanging metal. I know that sometimes the brake calipers will rattle - but this sounds like that plus something else. I know these front end "noises" are nearly impossible to diagnose with my description on a web forum... but if you guys were looking for a clanking sound coming from the front end... what would you inspect first and what should I be looking for? sway bar? maybe a bushing is bad? I do not have much experience with front end issues...and this sounds so ghetto fabulous its not even funny anymore...
Thanks!
abstract_72 is offline
Old 08-15-2008, 01:29 PM   #2
Re: Clingy Clanky Front end on Turbo Mini
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
You've answered all of your own questions perfectly. Get under there & start checking stuff!
Sittn86 is offline
Old 08-15-2008, 01:52 PM   #3
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
Images: 14
Ball joints, tie-rod ends, upper strut mounts, control arm bushings, sway-bar
bushings, wheel bearings, loose lug nuts, loose steering rack-to-crossmember
bolts,......
ol"blue is offline
Old 08-15-2008, 02:34 PM   #4
Perhaps both the problems you posted in 2 different threads can be traced back to a bad strut?
Sittn86 is offline
Old 08-15-2008, 04:15 PM   #5
The struts seem to be ok - they are just really soft... like I can push the front end of the car down pretty easy when I put my weight on it...
Mortgage Calculator | eBay | Secured Loans | Buy Anything On eBay | Loans
Page generated in 0.36334 seconds with 13 queries
