08-16-2008, 09:25 AM
Strange brake problem... low fluid flow to one wheel?
My 92 TBi shadow has an odd problem with the brakes. The left front wheel is getting very low fluid flow, causing the car to initially pull to the right under hard braking. I started out by replacing the calipers, thinking it was a stuck caliper, but as soon as I went to bleed them I could see that the fluid flow was obstructed somehow. There is no obvious external damage to lines. I haven't yet checked the right rear wheel to see if it is the whole circuit or not. The brake lines are old, and it's unlikely I will be able to remove them without destroying them, so before I go chasing blockages between the wheel and the master cylinder, I thought I'd see if anyone has been through this before.
thanks,
william
