08-21-2008, 10:18 PM
Re: Fake steel rims?
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
Some 91-92 Imperials came with something like those, with obviously more offset and in 5x100. They are 14s though. I had THOUGHT that the Imperials came standard with the large rotor set-up as standard, but these rims won't clear the 91 setup that I have on the Duster now. If you have the large bolt pattern, you have the large brakes on your C/V, and you're basically SOL on fitting them.
I picked up a set back when I had an Imperial for a bit, I threw on a set of perfect cathedrals in their place, thought the car looked better that way. I junked the car later, but the rims are still down in the garage.
You can ID them easily enough, the face is machined, leaving visible tool ridges in circles around the rim, and the metal thickness visible through the holes is obviously thicker than the steelies. I'll post up a pic tomorrow evening, I need to excavate the garage anyway.....
Oh yeah, they are indeed lighter than the steelies. Maybe a good 4 pounds lighter.
