Old 08-27-2008, 10:04 PM   #1
rear drums to rotors
My Ride: 1986 daytona turbo z
Hey,
I've got an 86 daytona I like to convert the rear drums to rotors. I just got an 87 daytona parts car with rear rotors. Can I just swap these and change the proportioning valve?
tthcare is offline
Old 08-28-2008, 09:54 AM   #2
Re: rear drums to rotors
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
do a search on "SLH upgrade" ; on TD and also the web
detobias is offline
Old 08-28-2008, 10:23 PM   #3
Thanks for the info. Wondering if anyone else has done this?
tthcare is offline
Old 08-28-2008, 10:39 PM   #4
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (10)
If you are wanting to use the stock e-brake setup, you want to find an 89+ setup for the rear disc brakes, that way the e-brake cable will work fine. But in short you swap over proportion valve, master cylinder, front brakes from a pre-90 mini van, and rear disc setup. And you pretty much are done. I did the swap on my old Rampage and it worked great. There are parts of the SLH setup that have flaws in it, but it is a good setup to run with.
1983Rampage is offline
Old 08-28-2008, 10:59 PM   #5
Thanks for the input. I was going to pull the discs off of a 87 donor car. I didn't know if it was worth the time. Would it be a big improvment over the drum?
tthcare is offline
Old 08-28-2008, 11:43 PM   #6
My Ride: 89 Shadow
Engine: 2.5 turbo
i swapped 88 shelby z rotors onto my 89shadow a while back. easy and straight foward conversion. for the ebrake i just made some spacers to make them work. but check your master cyl. and see what size the piston is. it will be written on the top in the front.
Moparbishi is offline
Old 08-29-2008, 01:31 AM   #7
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
I believe the 87 rear calipers tend to have the screw style E brake that is specific and known to be crap.
Last I knew reman calipers for the 91 setup were $17 each at autozone so if you can get cores cheap that would be the way to go(but better have 11" fronts to go w/ th e11" vented rears)
speeduphoria is online now
Old 08-29-2008, 06:38 AM   #8
I'll pull the front and rear brakes from the 87 car along with the master cylinder and propotioning valve. Thanks
tthcare is offline
Old 10-11-2008, 07:54 PM   #9
My Ride: 86 Laser
I converted an '86 Laser over to 4 wheel disc using 11" vented rotors from a '90 Daytona with 16" wheels. I also pulled the spindles, so that the calipers would bolt on. The 16" setups are hard to find, but well worth the effort and fit the 15" wheels.
LaserDad is offline
Old 10-11-2008, 08:27 PM   #10
My Ride: 85 GLHT, 87 ShelbyZ
I throw 87-88 non-shelby rear disks in the trash
GLHNSLHT2 is offline
Old 10-13-2008, 04:37 PM   #11
I really don't want to go out and buy new or used parts for rear discs. I have a parts car and just wondered if it's worth the swap. If the rotors and calipers are really no better than the drums on the 86 CS I have than maybe just leave it as is? Still have to fix the Fred Flintstone floor boards. Maybe If I don't fix the floors a better pair of shoes.
tthcare is offline
eHarmony Coupon | Cell Phone | Homes for Sale | Credit Report | Repair Bad Credit
Page generated in 0.45326 seconds with 13 queries
