Old 08-28-2008, 10:30 AM   #1
SRT 4 spindles
Garrett Booster
My Ride: 88 shelby z
Engine: 2.5l 8v
has anyone compared or fit srt 4 steering knuckles to a g,p,etc-body? specifically the lower ball joint?
tmoney is offline
Old 08-29-2008, 04:57 PM   #2
Re: SRT 4 spindles
I know the part where the strut bolts up is wider. Don't know about the ball joint.
cdavis is offline
Old 08-29-2008, 07:03 PM   #3
Re: SRT 4 spindles
My Ride: turbo rampage
1984 and upto 2005 the lower ball joint is just about the same on most fwd mopar i just did research to put srt neon spindles on my 1984 rampage might have to modfyi the inner tie rods have not assembled it yet
wrench18201 is offline
Old 08-30-2008, 12:03 AM   #4
Re: SRT 4 spindles
Garrett Booster
Engine: 2.5l 8v
does the td outer tie rods fit the srt spindles? why r u using the srt tie rods?
thanks
travis
tmoney is offline
Old 08-30-2008, 12:09 AM   #5
Re: SRT 4 spindles
Garrett Booster
Engine: 2.5l 8v
yeah i found that out measuring a coworkers srt4 struts. i was hoping to use the srt aftermarket coilovers, brakes, and srt axles with the knuckles, to help with my 2.4 swap.
travis
tmoney is offline
Old 08-31-2008, 12:59 PM   #6
Re: SRT 4 spindles
I have been looking into using the 1st or 2nd gen neon coilovers for my shadow, since there aren't any decent struts for our cars anymore. 1st gen struts will bolt to the shadow knuckle, 2nd gen would need a spacer on each side of the knuckle, since the newer stuff is wider. Don't know about the strut mounts yet, may have to use c/c plates, hoping to use stock mounts.
cdavis is offline
Old 09-02-2008, 03:22 PM   #7
Re: SRT 4 spindles
could you use those double washers found on the later k based bodies as spacers?
capev86 is offline
Old 09-02-2008, 03:22 PM   #8
Re: SRT 4 spindles
the ones that look like the number "8"
capev86 is offline
Old 09-02-2008, 11:04 PM   #9
Re: SRT 4 spindles
Prolly could, but I would have some made, or make them myself, that would give full contact between the knuckle and strut.
cdavis is offline
Loans | Loans | Mobile Phone | BeSEO Computers and Internet | Buy Anything On eBay
Page generated in 0.39949 seconds with 13 queries
