Old 04-29-2003, 05:24 PM   #1
dropping k-frame / bushings
johnr7
on my 89 daytona I'm going to replace my control arm bushings and sway bar bushings - I'm thinking it might be easier in the long run to tie the steering rack up, drop the entire k-frame/control arm assembly and do the bushing swap with the k-frame out of the car.
Am I missing anything here? It seems like it would be pretty straightforward to disconnect the ball joints, unbolt/tie up rack, and drop the whole shebang. I could even por-15 it all while it's off the car.
Any opinions?
- John
Old 04-29-2003, 08:48 PM   #2
My Ride: omni glh
Engine: 2.2 turbo
sounds like a good plan
makes things easier to work on
and like you said you could clean it up a little
after swapping all that out it would be a good idea to get it aligned too.
glhs636 is offline
Old 05-02-2003, 02:56 PM   #3
My Ride: '87 CSX #360
I just recently did this, but I left the steering rack on the k-frame. The only hard part I needed help with was aligning the part where the steering colum meets the steering rack. Other than that it was relatively straightforward.
good luck!
StraX22 is offline
Old 05-03-2003, 01:30 AM   #4
what type of pivot bushings are you using, where are you getting them and how much do they cost, I have run into a problem where its going to cost me 200+ for new bushings from the dealer
London Shelby is offline
Old 05-03-2003, 08:05 AM   #5
My Ride: Dodge Omni GLH clone
Engine: 2.2 inline 4
Quickor & Energy Suspension offer packages that are better than factory-if you are going thru the hassle of doing them, go Polyeurethane.
omnivore is offline
Old 05-03-2003, 10:28 AM   #6
johnr7
Mine are energy suspension bushings, part # 5.3107. Supposedly the right ones for my 89 daytona, time will tell. You can find them at:
www.fwdperformance.com
Go to catalog->suspension->rebuild/bushings
- John
Online education articles | Mobile Phone | Myspace Layouts | Credit Cards | Cheap Car Insurance
Page generated in 0.30926 seconds with 13 queries
