09-10-2008, 06:31 PM
Suspension Upgrades
My Ride: '87 Plymouth Horizon
Hey Guys, I've got myself an '87 Horizon, carb'd 2.2 auto. I've upgraded most of the suspension, new KYB GR2 Struts upfront, OEM Mopar struts in back, front Shelby Z 1.25" sway bar with new bushings and front upper strut brace. Springs are all still stock rate and length. What other suspension upgrades can I do to front/back to make it handle better with minimal cost involved. New Koni struts or Eibach springs are nice, but on the pricey side. Any other ideas that I might be able to make/modify/find in the wrecker yard myself? Ex. rear springs off another car, rear sway bar etc.
Many Thanks.
09-10-2008, 09:05 PM
Re: Suspension Upgrades
My Ride: 93' Turbo Duster
Engine: 2.5L T2
20 dollar tercel coilovers on ebay
Cheap as it gets.......
09-11-2008, 10:18 AM
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
heres some thoughts; not a complete list:
zero cost
cut stock springs a coil or 1.25; lowers center of gravity (CG) and increases spring stiffness
partially box in rear trailing arm to increase torsional rigidity = acts like a sway bar (some scrap steel and a MIG)
minimal cost
upgrade to GLH/SC springs
rear shock tower brace
upgrade to GLH/SC brakes
upgrade to 14 " wheels and run e.g. 185/60s
more cost
rear sway bar
upgrade to GLH/SC 15x6 wheels and 195/50 tires (will make a HUGE improvement)
09-11-2008, 08:00 PM
Thanks for info, I've got a few more questions, first, do the Tercel coil-overs work on the L-body struts?
Second, I've heard of the addco rear sway bar kit on eBay, are those at all worthwhile?
Third, if I cut the stock springs, does that weaken them or warp them, or perhaps better question, what's the best method to cut them?
Many Thanks.
09-11-2008, 08:46 PM
Engine: 2.5L T2
09-13-2008, 10:13 AM
Engine: 2.5L T2
get the tercel or eclipse springs, stiffer and should handle better. Plus you can ajust your ride hieght , and you will still have stock springs to put back in in case you want it stock again.
09-16-2008, 10:52 AM
#12
a proper anti-sway bar IS a better alternative to boxing the rear axle - but of course more $; Johnny at polybushings.com is the best source for sway bars ; they may even be the Addco's ; might be a couple $ more but his service is A+ and he's a TD guy
the best way to cut springs is with a cut-off wheel ; a sawzall with a metal blade will work too but be patient - thats strong steel ; you could use an oxyacetylene also but that would be my last choice, since it could affect the strength of the steel near the cut portion; otherwise the first 2 methods of cutting will not weaken or distort the spring
09-16-2008, 10:55 AM
#13
+1 ; if you run stiffer springs you will just overwhelm the shocks / struts anyways
thats why the only real choice for road racing or auto-X are the koni's with coilovers
but for Hard street driving I feel GLH/SC springs with fresh shocks&struts and good tires is MORE than adequate ; the L bodies are so light ...
