09-23-2008, 09:10 PM
Re: glht wheel bearing changing
My Ride: 85 GLHT
If you have a press, just replace the bearing. Unless the hub or knuckle is messed up. It's real easy after you remove the knuckle.
- press the hub out of the knuckle (the bearing parts normally start to come apart)
- use a bearing breaker with the press to remove the race from the hub (I've had to cut this off at times)
- clean everything up
- press the bearing into the knuckle
- press the hub into the bearing/knuckle
You'll have to be creative with the press plates and old bearing parts are helpful for pressing.
