Old 10-04-2008, 02:54 PM   #1
Question Popping and high pitch noise
My Ride: 1988 dodge daytona
Engine: 4 Cyl. 2.2L
Last week i noticed a popping come from the front passenger side wheel area, and a high pitched noise like a jet engine. The popping is at low speeds only while the steering wheel is being turned, and the jet noise is when i am moving at speeds above 40mph. i checked for play in the wheel while it was jacked up but it was tight, both cv joint boots are dry, but where the shaft goes into the transmission there is oil all around. Is there something in there(where the shaft goes into the transmission) that would make these noises when it fails or needs replacing?
jaykaybridges is offline
Old 10-04-2008, 06:08 PM   #2
Re: Popping and high pitch noise
My Ride: Starion
over posting. post once in the most relevant catagory
pobort is offline
Cash Advance | Web Advertising | Remortgages | Credit Check | Modded Xbox
Page generated in 0.32406 seconds with 13 queries
