10-13-2008, 09:07 PM
Re: Spirit R/T wheel issues
My Ride: '88 Shelby Z TII
K-frame is a possibility, however in my experience this problem has always been caused by mismatched suspension bits from '89/'90 with '91-up stuff.
There were several discussions about this a while ago, I beleive myself and CS Racer were both contributors to the threads. IIRC the mismatch between cast a-arms and '89/'90 spindles caused this issue do to the different location of the ball joint.
Being an R/T it *should* have cast a-arms and the 11" brake package with the bolt-on caliper adapter. If not, then the spindles are not correct and that is more than likely the issue.
If this is not the case, and those parts are correct, then the next place I'd look is worn a-arm bushings.
HTH some....
