05-15-2003, 04:21 PM
K Member upgrade again, Please help
The sway bar mount on my 88 Daytona ripped out of the K-member and cannot be welded back in, so I am planning on upgrading K-members. However, because it is my only daily driver, I need to make sure I get all the right pieces before I tear my car apart... Here is my understanding so far:
1) Either the 89 or 90 K-member will drop right into my 88 Daytona
2) 91+ cast control arms bolt right into the 89-90 K-member
3) Napa sells poly bushings for the 91+ cast control arms
??? 4) The 91+ control arms have a relocated ball joint for better alignment, and a bigger bolt goes through the ball joint. However, this DOES NOT prevent the 91+ ball joints from mating to a 88 knuckle/strut/brake assembly ???
5) The mounting holes in the 88 power steering rack might need to be enlarged slightly to fit on the 89/90 rack, but it should be a simple fix with a drill...
6) The 88 Daytona sway bar will NOT work on a 89+ K member ??
7) The Daytona K-member is identical to P, H, J body K-member's
What I cannot find a definite answer on is:
Do you need to change the knuckle, to get everything to fit together? i.e. will a 91 ball joint fit into a 88 knuckle and line up correctly?
I am planning on getting:
1) 89-90 cross member from a MANUAL car
2) 91+ control arm
3) 91+ sway bar and sway bar mounts
4) poly bushings for control arms and sway bars from Napa
If I get those 4 things, will I be able to have a running car after a long day's work, or will I be stuck with something that does not fit together? Thanks for the help.
05-15-2003, 08:30 PM
Yes, the whole k-frame (with arms) bolted right in.
I kept the original bushings.
Getting it lined up is a piece of cake. Put a floor jack under it, and jack it up until the rear bolt holes are on the studs. Then loosely install both rear nuts. Now jack up the front a little, then attach steering rack (use some thread lock). Make sure the ball joints go into the knuckles, then raise the k-frame until it's all the way up. Insert the front bolts to hold it in place (don't torque down yet). Now tighten the rear passenger side nut, this will align the k-frame. Tighten the other nut and bolts, then the ball joint clamp bolts, and you're all set.
I don't know how much it weighs... I'd say right around 100lbs is a good guess.
To make things a little easier, remove the splash shield (on the front center of k-frame) before removing/installing the frames.
05-15-2003, 11:03 PM
My Ride: All of them
Engine: 2.1 T1
1. Yes; just put 90 k frame into 88 Shadow.
5. Yes; the bolts are larger in and you will have to drill out holes
for rack and pinion. Did it with a drill.
6. Sway bars interchange. I had 1 1/4" from 88 Shelby already
in 88 k frame and put it into the later K frame.
7. P, J, and G definitely interchange. I think all from 87 K cars
and up interchange from what I saw in Mopar Action tech but I
don't have it handy to verify.
Like lametec said it is easy to line up and get in place. Only problem was getting steering column inserted. With two people working on it no problem. I did job by myself and it is a little tricky but it can be done. Didn't have anyone around to help.
Go ahead and do it; you'll be glad you did. Drives so much better.
05-15-2003, 11:41 PM
Does anybody know when, or if the steering knuckle changed? Are any control arms specific to a given knuckle? i.e. I have heard 90 control arms work on an 88, and I have read on the FMML that 91+ work on 90, but does anybody know for sure if a 91+ control arm will work with an 88 knuckle? It seems like it should, but I have also heard that the 91+ uses a ball joint with a bigger pin that will not fit into the 88 knuckle. The Napa catalog lists 2 different part #'s for 87-90 ball joints and 91+ ball joints which worries me. But then again, if the 91+ work in a 89, and a 89 works in a 88, I don't see why a 91+ shouldn't also work in an 88. Anybody know?
Also, I was planning on just leaving the rack in the car attached to the steering column, when I take out the K-member. Is there a reason to take it out? I figure it would be easier to drill 4 wholes a little bigger while under the car, then it would be to disconnect the power steering pump & column... Let me know what you think. Thanks again for all the great info!
