Old 05-22-2003, 01:31 PM   #1
Question Poly Sway Bar bushings from Quikor...
DaytonaShelbyZ
Just put them on my front sway bar last night. Had to grind about 1/2" off of the 2 inside bushings to get them to go in.
I am just wondering if anyone else had to do this?
If so, what are people without access to a grinder or something supposed to do? Sit there for hours with a razorblade?
Old 05-22-2003, 02:34 PM   #2
MrCSX55's Avatar
My Ride: 87 CSX #55
Engine: 89-2.2 c-block
Got a set for the swaybar I got off a 88 daytona shelby z. They fit the bar fine.
MrCSX55 is offline
Old 05-22-2003, 02:50 PM   #3
DaytonaShelbyZ
Maybe they just sent me the wrong ones.
Old 05-25-2003, 02:23 PM   #4
DaytonaShelbyZ
No one else?
Old 05-25-2003, 07:46 PM   #5
MrCSX55's Avatar
My Ride: 87 CSX #55
Hi Tom, when I got mine the 1-1/4" ones were 1-1/8". They were sized to fit. Put them on today, fit great.
MrCSX55 is offline
Old 06-04-2003, 10:05 AM   #6
My Ride: 1988 Dodge Daytona
Engine: 1988 2.2L Turbo II
I'm guessing if you look at your k-frame you'll see some U shaped metal brackets that have been welded to it where the inner sway bar bushings are mounted. These aren't present on all cars. My Daytona has them, and it appears as if maybe the factory ran out of the normal sway bar bushings and adapted the k-frames to take generic sway bar bushings.
As a result, the ones Quickor sells don't fit in there unless you hack quite a significant portion of the bushing off. I've got some pictures of both the bushings I got from Quickor and the ones I pulled out of the car here:
http://www.hellafast.com/images/bushing/
SilverShelbyZ is offline
Old 06-05-2003, 04:36 PM   #7
DaytonaShelbyZ
Yep, that's what I pulled off the car & what i got from Quickor and my tona does have those brackets welded in.
Hotels | video-n-digital-camera.com | Car Insurance | New York Hotels | Money
Page generated in 0.31009 seconds with 13 queries
