Old 06-04-2003, 12:04 AM   #1
loud noise like a bad tire
johnr7
I've got a rather sudden onset of a loud front end noise, kinda like excess road noise from a noisy tread tire.
Can this be due to a wheel bearing or CV joint on its way out?
It isn't related to engine speed, for what that's worth. I can shift into neutral (A-413) while at highway speed, no change in the noise.
It isn't clunking or grinding, just sounds like I put an off-road tire on.
Any ideas?
'89 daytona, original wheel bearings/driveshafts....
Old 06-05-2003, 12:06 PM   #2
My Ride: 1987 Shelby GLHS 507
Engine: 2.2 SOHC Turbo
sounds like a wheel bearing.. while driving if you change lanes quickly does the noise go away? if so, prolly a wheel bearing.
MoparBoyy is offline
Old 06-05-2003, 12:19 PM   #3
johnr7
If I take a sweeping right turn the noise goes away, resumes as soon as I straighten out.
Still guessing wheel bearing? I'm wondering if I go to the trouble of replacing it, should I just do the driveshaft at the same time...
- John
Old 06-05-2003, 12:53 PM   #4
O YEAH, its a bearing... naww, just do the bearing, its easy.
Old 06-05-2003, 01:21 PM   #5
johnr7
Alright, you talked me into it.
I believe my 89 daytona has the press-in bearings, not the bolt-in. I'll have to crawl under the beast and make sure.
Thanks,
John
Old 06-05-2003, 04:09 PM   #6
89 Dayonta shelby should have bolt in style
Old 06-05-2003, 05:24 PM   #7
johnr7
No shelby though, just daytona ES.
If they are bolt-in that will be awesome - but I don't think they are. The bolt-in don't have a 3-bolt retainer on the tire side, do they?
Because I saw that 3-bolt retainer on there when I was replacing my rotors...so I'm thinking press-in.
Secured Loans | Loans | Plane Tickets | Loans | Online Advertising
Page generated in 0.42608 seconds with 13 queries
