Old 08-04-2003, 11:49 PM   #1
Cutting Eibachs?
My Ride: 91 Shadow ES
Engine: 2.5L
Anyone know how to figure out how much these will drop the car per Inch cut off the bottom of the spring.. car is approx 2800lbs.. P-body. the pro kit eibachs appearantly drop the car 1.5", i would like to get 2" drop from it.. how much to cut off??
Radiant_Red is offline
Old 08-05-2003, 09:19 AM   #2
Hey Frank, I've had the P-Body Eibach's on my Shadow for over 4 years. I love em. I was happy with the rear height the springs gave. Besides, the rear coils would be trickier to cut and fit. I ended up cutting exactly a half of a loop on the bottom end of the front coils each. That's the large hoop end of the coil spring. A one half loop cut off with a cutting disc gave the car about a 2" drop in the front and a 1.5-1.75" or so in the rear. This look just gives the wheels about a 1 inch clearance in the fender well when looking from a sideview. The springs feel fine, the strut bearings are fine, alignment was fine, no wierd camber or caster look or problems either. Good luck Frank.
White Lightning is offline
Old 08-05-2003, 12:27 PM   #3
Re: Cutting Eibachs?
My Ride: 1991 Daytona Shelby
Engine: 2.5L
use the 87-88 front spindles. this will drop your height close to 1" when combined with your current springs and struts. this way is better because you are not changing suspension travel.
frank
Frank is offline
Old 08-05-2003, 01:09 PM   #4
My Ride: '88 CSX-T
cutting/heating springs is no good just watch me at the track. Also lowering your car will change the angle of the engine-axle-axle-wheel angle and can cause problems if you are drag racing, so keep engine trans alignment in mind when lowering you car.
squirrel is offline
Gas Suppliers | Credit Monitoring | Auto Loans | Homeowner Loans | Credit Cards
Page generated in 0.31557 seconds with 13 queries
