Old 09-18-2003, 09:38 PM   #1
Caliper failure!
Anyone have a caliper do this before?
banger68 is offline
Old 09-18-2003, 09:41 PM   #2
It was not pleasant.
banger68 is offline
Old 09-19-2003, 11:05 AM   #3
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
Looks like it cracked a while back and got corroded. I've had hoses and rear cylinder failures. It is scary.
dyno sheet
I practice what I preach:
1992 GTC convertible 2.5/568 aluminum fw/Tu 6puck feramic/s60/3in Tu sv/+40S/ FWD CAL /FMIC/self ported head+1mm exh valves/self ported ex mani/stock 2piece w/stock tb/PSSSSTSSSS
crazymadbastard is offline
Old 09-19-2003, 11:28 AM   #4
My Ride: Dodge Omni GLH clone
Engine: 2.2 inline 4
I just changed the pads on my 1 ton dodge maxivan. The pistons had a couple small pieces missing from them, about 1/10th the size of yours had missing. It had brand new calipers from Ma Mopar a yr and a half ago. Maybe this is common? Was this on the 86 daily driver CS?
omnivore is offline
Old 09-19-2003, 03:21 PM   #5
Yep. It stuck in the on position and boiled the brake fluid...45min from home. The previous owner was getting his parts at Crappy Tire...need I say more.
banger68 is offline
Old 09-19-2003, 04:37 PM   #6
Never seen anything quite like that, not even on a Jeep
kc8cie is offline
Old 09-22-2003, 09:42 AM   #7
My Ride: 1988 Dodge Daytona
Engine: 1988 2.2L Turbo II
Never had that happen before, but I've had a caliper lock up on me twice now.
SilverShelbyZ is offline
Free Ringtone | Debt Help | Myspace Codes | Online Degree Certificate | Computer Memory
Page generated in 0.79844 seconds with 14 queries
