Old 09-25-2003, 11:12 PM   #1
New TD'er... spindle swap questions
Hi All,
I've got an '85 N/A 2.2 Omni, with four bolt hubs. Will the spindles from '86 Lebaron convertible with five bolt hubs fit the Omni? Would they be a straight swap, and would a crab wheel have the same bolt spacing dimensions as these 5 lug hubs?
Thanks,
Glen
chryco63 is offline
Old 09-30-2003, 12:31 PM   #2
My Ride: 85 Shelby Charger
Engine: 2.2 T-II
No the Lebaron spindles will not work. You will need to find L body spindles or get 5 lug hubs.
tmef is offline
Old 09-30-2003, 02:15 PM   #3
iirc the only reason the 5 bolt spindles wont work is because the area that the strut bolts to is slightly wider... if you grind it down a little it should work fine..
or im totally wrong.
Vigo is offline
Home Loan | Loans | Share Prices | Cheap Car Insurance | Mbna
Page generated in 0.30054 seconds with 13 queries
